Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 31 Guests are viewing this topic.
Grumpy
Quote from GK;
How do we create a sonic or magnetic boom?
Stephan Marinov's MAGVID produces a rotating magnetic field inside the magnetic field of a DC solenoid coil.  AT about 30 MHZ it produced an output beam of light like a pulsar.  Probably burn a hole in your ceiling...
        -Frank Edwards
Thedane
A visual of the earth's magnetic field.
It's very cool to watch the waves move - and the relative long distance between them.
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=2034019524
Description:  Time-Lapse of gravity wave action from the Tama, Iowa on May 6, 2007 To quote some one much smarter than I, "A gravity wave is a vertical wave. The best example I can think of in describing what a gravity wave looks like is to think of a rock being thrown into a pond. Ripples or circles migrate from the point the rock hits the water. An up and down motion is created. With increasing distance from the point where the rock hit the water, the waves becomes less defined (the waves are dampening). Now let's look at what a gravity wave is in the atmosphere. To start a gravity wave, a TRIGGER mechanism must cause the air to be displaced in the vertical. Examples of trigger mechanisms that produce gravity waves are mountains and thunderstorm updrafts. To generate a gravity wave, the air must be forced to rise in STABLE air. Why? Because if air rises in unstable air it will continue to rise and will NOT create a wave pattern. If air is forced to rise up in stable air, the natural tendency will be for the air to sink back down over time (usually because the parcel forced to rise is colder than the environment). The momentum of the air imparted by the trigger mechanism will force the parcel to rise and the stability of the atmosphere will force the parcel of air to sink after it rises (you have now undergone the first steps into creating a wave)..."
Motorcoach1
howdy folks : I ment to post this a while back , some one asked where i got the flat copper roll I posted photos of.  It is foil used in stained glass fabrication. I had a feww rolls laying around from my art studio , it comes in diffrent sizes too and has glue on the back or just leave the paper seperator on it. Have fun makeing flat mobius coils from it.    Mike ----it likes real high frq's tooooo and you can get it to float on high RF                 @ Eral most of us don't have EXL would it be hard to post in PDF format ,,,mmmmm ? thanks
eldarion
Quote from: Grumpy on June 07, 2007, 12:56:41 PM
Grumpy,
I hadn't heard that before.  Where did you find that?
It sounds amazing... ;)  And also like the odd "scalar beam" some people says looks like a beam of light shooting out of the top of their device.
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
