Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
innovation_station
hello gk and all
in playing around today  i got my neos out agin  ;D
such fun i have with those little things well i just wish there was an easy to control them but it seams like is it a hard thing to do
i havent seen many play with neos  and well it is just so much fun i think they can teach much here altho how much more must be taught  is there a way to harness power from the neos ? easly?  the ring i am playing with today is about in its simplest form and you all know how i like simple right
i realize most of my posts are not relivant to the tpu but then agin maybe they are i will not know fior sure until i finish it or get output  from it
a picture of my setup as of today i threw some other parts in the mix to see what happins it is a mess but it is much fun
ist
you all think this will light a bulb?  lol
Bruce_TPU
Quote from: innovation_station on August 23, 2007, 06:28:13 PM
WOW!!!! i just can not beleave how much darn electricty comes from 1 aa battery i really encourage others to play with this too cuz wow!!!
Hi IS,
Great job with posting your experiments.  I admire your excitement.  I just wanted to clarify for any novice readers, that there is not more electricity from the battery, simply more voltage.  The electrical power remains the same according to Ohms law.  Volts x Amps = Power.  That batteries power has not changed. By increasing the voltage, the amperage drops.
A 9 volt powered stun gun can produce 150,000 volts, up to 300,000 volts.  The current is miniscule and the "power" never changes.
I just wanted to clarify this for any newbies, reading, and thinking incorrectly, of course.
A spark of electricity called "static" electricity is about 1000 volts, but no current whatsoever.  It stings, but that's about all.
Cheers,
Bruce
giantkiller
All these steps add up. The GK4 is an accumulation of alot of great thinkers, experimenters, and brave posters. 8)
To much I owe alot of gratitude for. But it aint' finished yet.
--giantkiller. Back to the future.
giantkiller
And the proof is the ECD has wing edges and produces Radiant energy.
The Turbo coil has 2 wing edges on the vertical plane.
The Helmholtz's are in place and collect the RE.
The feedback conducts to the horizontal winding adding to the bobbins.
The attempt of placing the copper fence only shorted the RE out.
The placment of the aluminium plates caused the RE to squeeze out like a squashed Oreo cookie causing me to get stung off the edges.
The radiant energy exhibits properties similar to solar coronal mass ejections. NO! You don't say? It can't be twue.
Probably explains the sun icon in Turbos MT picture a while back.
Innovation_station suggested the Oreo cookie analogy. Thanks. :)
