Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
EMdevices
Grumpy
Quote from: bolt on September 13, 2007, 08:59:46 PM
this is my post from last week.
"Why SM may need to use balun? This could also be useful to provide the correct impedance of  the sig output to collector. The sig gen will be very low impedance and unbalanced even the mostfet PA stage is designed to run into very low impedance..few ohms. The collector coil will appear as several hundred ohms balanced. We know that a twisted pair has a 300 ohm impedance same as EDIT folded dipole (open unbalanced dipoles usually low impedance 50 or 75 ohm) and the collector coil could be as high. If the sig input is mismatched then we cannot transfer enough useful signal in to the collector. While writing this it certainly occurred to me the collector is a magnetic dipole!  LOL oh heck it gets better. The two collector coils ARE balanced and fed into the balun."
OK you said balun a week ago - not yesterday.
EM has a good idea with the "Directional Coupler".  Not RE after all, at least not directly...
Time for some experiments...where's me magnets?
        -Frank Edwards
Mannix
Grumpy
OK.  Let's see here.
Transverse wave Eddie is opposite and opposes.
Longitudinal wave eddy is perp, so does not oppose.  Isn't that cool?
So, drive controls at Longitudinal resonance freq and you see current in the wire.  Right in front of us the whole time - ain't that a bitch?
(Where's Mark Snoswell?  He has a thread on Longitudinal experiments.)
Reference to Schumann Resonance and 7.x Hz was only an example.   Resonance for TPU is relative to diameter just like Schumann Resonances are related to earth's diameter and propagation speed of EM.  So, using same correlation, one can get idea of correct TPU freq.  Smaller TPU will require higher frequency.
http://en.wikipedia.org/wiki/Schumann_resonance
        -Frank Edwards
tao
Quote from: Grumpy on September 14, 2007, 01:03:42 AM
OK.  Let's see here.
