Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
starcruiser
Quote from: giantkiller on March 01, 2007, 09:33:16 PM
@starcruiser,
I was in the lab with someone and in a discussion about Radiant Energy. If that energy can go through anything then anything can become a short. We talked about keeping everything out of the center space of the ring so the field would have no interference or place to go to as the center field commences, condences, & compresses. Just a thought.
GK, the electronics were not in the center during this test but still on my large breadboard, I used several jumpers to connect it to the TPU, so it was about 12' away or so.
I wanted to test the circuit (and the concept) before I built a proto board and made it more permanant. I will now do this over the weekend.
As for the circuit here is what I am using
This is the circuit is part of the driver circuit from the Bendini window motor. Note the extra coil I drew in for the secondary/collector. The feedback side of the circuit only requires a 1v pulse to trigger the circuit, I tested this with my signal generator to determine the trigger point. I am thinking of swapping the resistor out for a 2k pot to allow adjustment of the sensitivity.
Anyway more to do.
Regards,
Carl
starcruiser
Quote from: joe dirt on March 02, 2007, 03:11:55 AM
Hello all
Does anybody know who this is ?
http://www.youtube.com/watch?v=nm6M5vke-u8&mode=related&search=
Not sure why that guy posted it but it is not his unit or video. That is CTGLabs TPU/video. This unit is not functional.
BTW, can anyone translate the words on the video, I would be interested in what he is claiming exactly.
Regards,
Carl
mkt3920
Quote from: Sauron on February 28, 2007, 02:47:37 PM
O great DC Voltage produced by the electrical fields,
Would you care to talk with the o so great external magnetic field?
Maybe we both could have a little chat with the great queen of the AC currents.
Then the 3 of us can play a game.
Let's invite Mr ans Miss Frequency too,they know exactly how to play the game.
Perhaps we all can "kick" some ass.
Mister Schumann will be there too.
He knows all about specific numbers.
But i must warn you, he does not want you to come too close.
So try to keep an eye on him and keep it at some distance.
The winner of the game won't be cold.
Good luck to all.
I really liked this post.  It reminded me of Mannix/SM post from long ago.
<quote>
Now you know that the 5U4 requires 5 volts AC at 3 amps for its heater to gather the electrons and complete the circuit. Well, I measured the output from the tube and the result is 500 volts DC at 250 mV. The loss is due to the high impedance of the tube and its limited ability to dissipate more than 250 mA.. The point I wish to make here is that also along with the 500 volt DC is, yes, you guessed it, the 5 volts three amp AC current! They are both completely independent of each other except for some very interesting things I will mention to you some other time..
First of all, obviously you can have several different output components in the power output signal. You can have DC and AC together without any problem. Why did that mystery person claim that it was a foolish to say DC output with a 5k Hz component? Because he was deliberately trying to mislead anyone who might want to figure out what I was doing.
<stop quote>
Kent
mflynn44
Consider this configuration for the TPU. How about a neon transformer tank circuit operating near resonance. The high voltage across the capacitor is fed to a magnetically quenched spark gap. In series with the spark gap is a two turn primary. The secondary is a long coil of fine wire so that there will always be a train of pulses. That is, no pulse will reach the end of the coil before the coil is again pulsed. At the end of the coil is an Avramenko plug to pull electrons from the vacuum. Power is taken from the system across the capacitor which is part of the plug.
SM quote "When I accidentally stumbled on a device that appeared to actually pull electrons from the sky".
Sauron
"There is no mass circuitry involved, it is just the knowledge of the coils and how they interact with each other"
