Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 38 Guests are viewing this topic.
FatBird
GK said:
And my update is:
I have 3 collectors stacked. Each collector has 1 segment controller, all 4 of each layer in series.
I run a frequency through the collectors and a 2nd frequency thru the control coils, all layers in parallel. There are no feedbacks connected. They are just there in the coil.
Results:
I can burn up trannys. I now get kicks no matter what frequency range I use. And the kicks eminate from the coil. You can physically feel and hear them. No tones coming from the coil.
It is a stun gun without the spark gap. The physical feelings are not as experienced as a stun gun, but they are there.
I now am going to try different jumpering. I don't think I have to though. I have the very basic and simplest wiring configuration. I am going to work on the feedback to cause a ramp up for power. All of SM's TPUs do 'ramp up'. I am going to place a spark gap between the configuration I have now and the addition of the feedbacks. Of course I'll experiment with frequency combinations.
The effort has been to try to get power out. I'd be a fool to enter a skateboard into the Indy 500 or expect to throw a Frisbee to the Moon. Get the circuit to ramp up and let the power come from where it is instead of trying to generate it.
--giantkiller. It already exists.
Thank you for sharing your new circuit GK.  Are you using copper or Garden Wire?  How many turns on each coil?
Thank you.
giantkiller
@Fatbird,
I apologize for the lack of info and I hope enough people see this. I am using my sequence controller / driver with GK4. Same ol', same ol'. Lords of the ring page1 post 2. I know what I have is close because it is a totaly open configuration. Build once, use many.
Let me re-iterate! I cannot avoid or get away from the kicks now. Man, is that a proud statement? Imagine that?
I told an audio technician in Guitar center that I took a speaker, removed the cone, and moved the voice coil to the outer ring, and place microphones in the center and drove the outer ring like a transmitting antenna. I then asked why would I do that? He immediately said 'You'll blow the whole frickin thing up'. I stated 'Exactly'. I then asked 'What if I also placed a power pickup in the center in the feedback loop?' 'You'd have some kind of generator' he replied. I placed GK4 in his hands and I just looked at him and then you should have seen him light up! The rest is history. I am doing other tasks to get this known. I pick my victims well.
--giantkiller. It is a good day to rock!
If I had wanted to take the other pill I wouldn't have gone down this rabbit hole so far.
Mannix
Quote from: MrMag on March 13, 2007, 06:30:40 PM
I know it's fun to build but wouldn't an old tube sine wave generator serve the purpose?
I found an old Heathkit model IG-82 on eBay for about $30.00.
I've attached the schematic if anyone is interested.
Good one, fat bird,
now you will need two more..
That the problem I had...that's why I built them..
The circuit you provided is a wein bridge type..the best but a lot to build I hope that you can find 3..I wish you the best skill and luck.
Steven started with 3 old tube generators ..driving tube amps.
Lindsay
ps
GK, we may look back soon and wonder why we could not see it ...
otto
Hello all,
if youre interested in such a shematic google: tesla coil with transistors and you will have a lot of informations.
Otto
