Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 23 Guests are viewing this topic.
Sauron
hi Giantkiller,
i have seen many tpu's you build but i have never seen you lite a single bulb or some real power output...
may i ask how far your project is from a working device?
also, do you think this is used in a tpu?
giantkiller
After I got kicks on Jan 13 I got interested in what would produce kicks using other things. I also read the other posts after that others were able to get kicks with their TPUs. Of course Otto was before me with other coil type configurations. I was starting to realize that kicks were easy to get because they look like BEMF. So I started putting together coils of different ilk just to pulse them. That is when I realized stunguns were a great driving source. Noisy but useful. So now I am in conferences and am focusing on the picking up the output to feed them back. My 15" ring was fired by a stungun and shut down my computing devices. I stunned my GK4 from top cw to bottom ccw connections and blue lightning conducts around the ring from top and bottom. I stunned Mighty Little same way and same effect. Lightning jumping the ring conducting between top and bottom across the middle. So these basically are large area stun guns. I was curious if I could tranfser the stun gun output at a distance through other type spark gaps and I did using an open fuse and 2 nails in a plastic tube. I had posted that.
These experiments showed real energy but no power. I am interested in the wide range of coil configurations. The stungun is unsympathetic output. Major noise. So that will not be usable in a working TPU. Resnonance can not be reached with that kind of wide spectrum output. This experiment was pure fun. I got parts and time. The stungun, the bedini motor, the TPU all produce kicks and the output is feedback in some fashion.
I will look at the transformer specs posted.
I don't mean to create alot of noise with presentations and little or no results. I build 'em and fire them up. I am showing Mighty Little to some people and want to leave off the feedback for that then I am going to put the feedback on and jumper it for kicks, then turn it on and see what the smaller size does. The little coil was built while watching a movie from spare parts.
--giantkiller.
innovation_station
innovation_station
Jdo300
Quote from: Sauron on March 25, 2007, 03:58:06 AM
hi Jason
do you think something like this is used in the tpu?
it is also square at the top and bottom.
Hello Sauron,
I gave your question some long thought?. and then I thought some more? and the one thing that I can connect between that transformer and the TPU is the simple explanation of what a transformer does. It converts between electric and magnetic energy; something that seems to have resurfaced lately in some of the earlier discussions about the role of iron wire.
I also noticed something else in the video clips of the open TPU that seems to have eluded me earlier:
If you look closely at the windings, you will find that there are shiny spots at specific intervals on the control windings of the open TPU. Assuming that ordinary red and black speaker wire was wound on the unit, the insulation isn?t normally that shiny unless a bright spotlight was shined on them. Since this didn?t make sense to me, I studied the video more and realize that there appears to be strands of bare steel wire wrapped in the gap between the windings of the speaker wire! If this assumption is in fact true, there are some serious implications by doing this. If we assume that the red wire and black wire have opposite currents flowing in them (bifilar coil), then there is a special effect that Mr. Mark may be taking advantage of. Check out my diagram below.
We know that two opposite currents flowing in adjacent wraps of wire produce a canceled magnetic field. However, we must realize that this net canceled field is observed at a distance from the coil. If we zoom down to the gap between the two conductors of speaker wire in the coil, the magnetic field is, in fact, Not zero. It adds at that point to produce a north pole that extends out of the coil at right angles to the core it is wrapped on. So if the iron wire happens to be placed in that gap, that North pole (or south pole depending on the current flow) would magnetize the iron as the pulses were fired. Now, we know that the iron will hold that pole orientation for a lot longer than the copper will once the pulse in the coil shuts off. So, my hypothesis is that the iron wire?s magnetic field will act to sustain the current flow in the bifilar coil, which is consistent with what innovation_station was seeing in his experiment. But in addition to that, since the iron wire is iron, once magnetized, it may magnetically couple with the earth?s electromagnetic field even more ?coupling with the magnetic component? to convert even more energy!
More to come?
God Bless,
Jason O
P.S. I also attached an article I wrote about making radially magnetized coils, which applies to my theory here.
