Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Sauron
the example about moving the magnet across a wire was nice.
the explenation about the speed being important was very nice too.
but i still did not hear anybody talk about the number of magnets...
suppose you could have 15 magnets flying across the same wire ,faster than the speed of a gunshot, what would happen?
innovation_station
innovation_station
Sauron
No, the field would just merge to one magnet unless the fields are opposite.
lets read some of Stevens words again,
Let us say that you have a magnetic field perhaps it is only a small permanent magnet.
Now, you have a single copper wire twelve inches long.
If you move the magnet across the surface of the wire from left to right at a certain speed you create an electron flow which is DC and it has a power potential based on how strong the field is and how fast the magnet if moved.
So, if you increase the size of the magnet or the speed it moves you create a larger flow of electrons, larger as in higher voltage or more currant.
If you had a short wire and you moved a magnet across it you would always have limited potential because the length of wire was so short.
OK now what if we increase the length of the wire to many miles in length even with a very weak magnetic field moving across the wire you still have a much greater potential flow of power available.
If we put it into a perspective of power per inch it may be easier to understand.
If you have a small magnetic field moving across a wire twelve inches long it can generate an electron flow equal to lets say one millivolt per inch.
If you move the magnet twelve inches at the same speed you get 12 millivolts as you transgress the twelve inches of wire.
Understand that I am trying to convey a principal that you can understand for use in the future.
So, you have a wire twelve inches long and you can make 12 millivolts moving a magnet across it.
If you have a wire 1000 feet long and you move the same small magnetic field across the length of it you can create much more voltage potential perhaps 12,000 millivolts lets say.
So, you have managed to generate a significant amount of electric power with a weak magnetic force.
OK, how does this help us? where am I going with this?
Suppose you have 1,000 pieces of wire twelve inches long and you run the same weak magnetic field over them all at the same time..... you get the same flow of electrons.
If the wires are run in series then you will get the 12,000 millivolts etc.
If you connect the wires in parallel you will get higher current but lower voltage.
However, the power potential is the same whether you run the wires in series or parallel.
If you know how to find the circuit potential, you tune into the frequency and you have enough short pieces of wire you can convert as much power as you wish in a given space.
you would be fascinated with the amount of renewable energy you can extract from a permanent magnet!
innovation_station
