Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 17 Guests are viewing this topic.
leeroyjenkinsii
Where do you guys get Steven Marks original/authentic writings from?
innovation_station
@btentzer
ha!!!
you and your whole underground crew wait for someone else to do the work
ha!!!
sounds about your speed
ist
i managed to find some small feroitte rings you all think they are too small? they are 1" x .5" with a .5" hole in the centre
i found a video on youtube with a verry familiar voice we all know he was demonstrating a magnet motor purly mechanical verry neat  ;)
if i come across it i will drop the link here
well i found the link listen to his voice sure sounds the same as sm in the tpu videos but if im wrong no loss it is a verry kool vid half way down this page
http://www.newebmasters.com/freeenergy/index.shtml
Bruce_TPU
Quote from: innovation_station on September 16, 2007, 08:42:01 AM
@btentzer
ha!!!
ha!!!
ist
@ ist
Now, William, that was not very nice, nor true.  I and others are doing great work.  Also, GK is one of those.  So try to play nice.
@ All
I agree completely with Mannix, that if this experiment is to have a hope of succeeding, it should also be duplicated with tubes, and see if there is a difference.  IST and Mannix, both of you have tubes, why not conduct the same experiment and compare it with GK's results?
This is an experiment that more than one person should attempt...in my humble opinion.
@ Bolt
Perhaps you could put together a schematic of the controller with the help of Mannix and how it would look, using tubes.  This would be a great help to some, who would like to experiment in that direction.  Thanks!!  This would give GK's results, lined up against another's results, using tubes.  And we can really see if there is anything to our ideas, without feeling we missed the truth (conversion, catalyst) because we did not use tubes.
Cheers,
Bruce
EMdevices
Gothic, that is a great posting.Ã,  thanks
Nice work GK and Mannix
innovation_station
@bruce
i apoligize but this is opensource
but i think we would have gotten further on this project if you  and the rest would have continued to post public insted of hideing in the shadows
william
well i was going to build the 3 layor but insted i will build the one bolt posted like the sm 15 and the sm 17  my gages are not just right on the wire but it dosent matter  this is to show what i finally see  out of all this and if it is wrong then it is 1 less that some one will have to do
hummmm.....             funny thing......
157" or 13'1" or 3.99999 m   on a 4" tpu  works out to  exactly 10 turns just thought i would mention that
my new ring a quick pic i just threw it to gather i have not started the controls yet or the center coil
