Free Book "Harvesting Torque From Permanent Magnets"
Started by Lunkster, December 09, 2020, 02:58:11 PM
aether22
Free Energy is possible in any system where there are large balanced energy gains and losses.
See, we say energy is transferred, but REALLY it is being created and destroyed in equal amounts.
But sometimes that creation and destruction is balanced within a system such as a series of permeant magnets, the attraction and repulsion is inducing lenz law effects in even permeant magnets, either pulling on or giving to the microscopic currents.
What you want is to have ideally megawatts of energy being created and destroyed with little energy having to be put in, consider a theoretically perfect system of magnetic rotors and stators undergoing attraction and repulsion, energy being induced in the magnets and taken from it s it turns freely, coasting.
This large energy shuttling is key, it can be done with batteries, capacitors (charge the middle plate with two in series) permeant magnet motors and motor generator hybrids, output pair coils, and series bucking bifilar coils.
You could wind a Tesla Coil secondary as a Bifilar and pass 10 amps DC through it with the HV oscillating at the some time, this would have HUGE virtual power gains and losses in the two halves of the circuit, like batteries back to back one charging one discharging.
Or, indeed tank circuits...
The point is that you need large amounts of energy being "processed", this kind of activity both creates and mixes aetheric energy with electromagnetic energy.
Pretty easy to implement this stuff!
Floor
@Lunkster
It looks like some serious time and energy went into the build.
              Nicely done.
Thanks again for sharing the design and build with us.
I recommend that experimenters build test benches.  If you put the same kind of time and
energy into building a test bench, and if you build it versatile enough, you
can test many different kinds of magnetic interactions and modify / reuse
the test bench.
Make the test bench / device modular.
Then hone your skills and knowledge in how best to measure the energy present in the
magnet interactions.
You can look at the test bench I use, for starter ideas on how your test bench design / build
should go.
examples
https://www.dailymotion.com/video/x6va1an
  and @
https://www.dailymotion.com/video/x59r978
There are basically two ways to go.
1. Proof of O.U. because its a self runner.
               or
2. Test / measure each interaction / element of a design, to find the energy
input or output in that element. Then build a test runner.
The second option is faster and a better learning environment / opportunity.
How to make and interpret the measurements is not very difficult, although it requires
some time and commitment.   It pretty apparent you have a lot of commitment.
   regards
          floor
Hello Lunkster,
here is a belgian patent archive listening :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=be&AP=&PR=&PD=&PA=&IN=&CPC=&IC=h02k53&Submit=Search
Look for the different numbers their
Publication info:  AND                (B1)
Probably fine experiments results ,some * granted after examination*, to refind !
Here a relatively easy descripted motor-generator arrangement : Watt1/Watt2  RATIO !
https://worldwide.espacenet.com/publicationDetails/description?CC=BE&NR=438189A&KC=A&FT=D&ND=3&DB=EPODOC&locale=en_EP#
66. The generative Unruh' or Tourbill(i ;) )on or Tornado
Sincere
OCWL
p.s.: deleting this poste ? ::)
Lunkster
Lunkster Update:
After I wrote this book, I decided to look into generator concepts because that seems to be of more interest at this forum than anything else.
So in 2021 I developed in theory a new concept of generating electricity.
How it works is that I have the generator design arranged in such a way that one electromagnet will reroute the flux flow of several permanent magnets in the generator.  I place coils in several places in the design in order to generate electricity through these changing flux paths.  THis rerouting can be performed at speeds of other generators.  The collective electrical energy of the several coils in the generator from the control of one electromagnet should be a better design than has been researched so far.
The great thing about this new technology is that it can be used in motors as well.
The motor has two stator assemblies each controlled by one electromagnet.  It has one rotor having only permanent magnets in it.  So the PM to EM ratio of one of the motor plans I have in the book is 12 to 1.  THis is far better than the 5 to 1 ratio from the motors in my free book.
This design is different than anything I have shared on-line so far.
The name of the book is currently sold on Amazon.  I am not sure how long they will be allowed to sell the book.
AAAAA Amazing Apparatuses Applying Abundant Abilities
Chain reaction of flux switching in generators and motors:
I will use most of the proceeds of the book to further my research and lab development in my basement.
Lunkster
