Pcb design which are needed for free energy
Started by justawatt, February 21, 2021, 10:55:32 AM
justawatt
the Russian circuit is tested and modified to working from 8 khz to 150 khz ,can the cap  " c22 "on sg3525 from (10 nf to 1 nf  ),
if push pull is not used ,we can you this circuit board  as above pulse packer circuit along with the driver
forest
Nice. But how to adjust it , how to make a working device coil design and so on ?
Shorted
Thanks! But part numbers on schematic are totally different than part numbers on PCB. Is there any PCB compatible parts list available?
justawatt
Which one is it.
See the schematic in the pdf not in the photo's.
It should be same.
Download the esayeda software you can edit the circuit and also get the part list there
justawatt
Quote from: forest on February 26, 2021, 06:28:21 AM
Well that's a good question .
I cannot answer that .try it .
Rusla's friend told all the circuit are open sourced .
The circuit in the net is enough to make Ruslan device
