Bullet blimp.
Started by synchro1, March 02, 2021, 08:26:34 AM
synchro1
We should be able to attach 2 ring props to drive the blades of an overhead fan, each powered by an inductivly coupled pulsed DC or AC motor, and send power back to the utility company. The 2 to 1 lift advantage of the ring prop should be able to power the AC fan as an alternator and furnish a breeze.
https://www.plantservices.com/articles/2003/26/
During the research for this column, I ran across several citations directing me to the next Web site, http://home.earthlink.net/~fradella/green.htm. That suggests the site offers something more than one person found worthy of highlighting on their own sites. The grand conceptual work, called Building-Integral On-Site Solar and Wind Power Systems by Richard/Dick Fradella, owner of a company called Regenerative Power and Motion, suggests wind and solar systems can be constructed as integral elements of the building itself, instead of stand-alone add-ons. This approach provides the equipment with a rugged support structure and protection. The article goes on in some level of detail to discuss the required systems and components. It's an interesting read, that's for sure.
https://web.archive.org/web/20060210232921/http://home.earthlink.net/~fradella/green.htm
Probably some interestant and relevant points to find ,
as example,not wind or magnets relevant, but solar :
"  ........ We can do far better. We can double the power from the same PV panels, protect the grid from "live loads" and provide uninterruptible power.  Here is how:   ....."
https://newsroom.unsw.edu.au/news/science-tech/pioneering-solar-energy
they designed in the End80´a 24/365 solarglider,solar energy absorbing flying power plant
probably you can compare and compete with a 24/365 windglider  ::) ;)
"doubling/four times (or more)" is a universal flow velocity accelerating (reverse decelerating : 1/4 to 1/8 )effect ;
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=10102672&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
The theory of flow energy concentration is known from DE magazine Sonnenenergie 2/84, and from DE-PS 33 30 899 an arrangement for concentrating flow energy is known.
[0004]
The flow field around an arbitrarily shaped vortex filament and the electrotechnical field around an arbitrarily curved, wire-shaped conductor are described by the same relationship:
        Biot-Savart's law.
If you wind a vortex thread with induction G into a bobbin, there is a concentration of speed over the winding axis.
The additional speed vZ results from the relationship VZ = Γ.n / l, where n is the number of vortices and 1 is the coil length in meters, analogous to electrical engineering. If eddies are generated on aerofoils positioned at an incline in a star shape, edge eddies corresponding to the aerofoil theory arise, which through self-induction form a double fluidized bed coil downstream. In this way, several vortex threads can be wound up to form a multi-thread vortex coil concentrator. For the first time it has been proven that a pressure difference to the static pressure of the atmosphere can be partially converted directly into kinetic energy with technical systems. All processes can be traced in a parallel flow with mass particles flowing in this partial order. Gearless systems can be built to utilize the generated core flow.
                                    donut or torus like
https://worldwide.espacenet.com/publicationDetails/description?CC=CA&NR=1117868A&KC=A&FT=D&ND=3&date=19820209&DB=EPODOC&locale=en_EP
Little has been done inthe way of molding, shaping, directing, or increasing the velocity of the fluid upon the rotor arrangement. In theory, the power available ~rom a fluid current is propor~ional to the cube of the fluid current velocity.
If the existing fluid velocity could be doubled, the power output would multiply by a factor of 8.
as mechanical shaft force or transformed by generator as emf
How far/near this trial : https://translate.google.com/translate?sl=de&tl=en&u=https://www.psiram.com/de/index.php/Air_Motor
p.s.: it was 2005 the question to change "flux amplifier"-effect by magnet/magnetret to electret/captret ! It works also  ;) :)
                                               https://overunity.com/1829/cpg/   Reply #10 on: December 28, 2006, 01:24:08 AM
                            alternatives: with permanent magnets or electro-magnets.
  publicated : 1983-12-09   ( 2007 the algerian inventor was alive,my father phoned to there,2021 not know the state)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=25&ND=3&adjacent=true&locale=en_EP&FT=D&date=19831209&CC=FR&NR=2528257A1&KC=A1
L'esitation de la bobine peut entre faite par une autre source d'alimentation et sera commandée par un relai temporisé electronique, comme il peut y avoir une bobine sur chaque pole de l'aimant, ou que l'aimant inducteur soit remplacée par un électroaimant.
Trés bien ! ::)
Not french-phonic ? Anglo-phonic translation :
Coil esitation(google,I would write : excitation)  can be done by another power source and will be controlled by an electronic time relay, as there may be a coil on each pole of the magnet, or the inductor magnet is replaced by one electro magnet.
This was the inspiring "flash" to combinate with Dr.Pavel Imris "capacitive winding"-technique 2007/2008 !
Or : as his publicated " electric generator" -version ( now -2021-  in several kinds available )
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=pavel+imris&CPC=&IC=&Submit=Search
Future design :
https://patentauction.com/patent.php?nb=13727 and a more efficient electric motor ,assuming -50% less consume compared conventional :
Net Zero energy room cooling,Net Zero energy refrigerator(3. rd world medical storage,food storage  )
To get the net zero :
recuperative part coil coating (David Yurth) or
https://worldwide.espacenet.com/publicationDetails/originalDocument?FT=D&date=20080812&DB=EPODOC&locale=en_EP&CC=US&NR=7411363B2&KC=B2&ND=4
Conservation of electrical energy and electro-magnetic power in motor, generator, and product components
synchro1
This is what I'm talking about :
synchro1
Closer look at the Fock Wulf wing: This jet wing could pass for an overhead fan.
