Bullet blimp.
Started by synchro1, March 02, 2021, 08:26:34 AM
synchro1
This ingenious swivel gear pearl is the "Gimmick" pictured below. Inserting a craft stick between slits in the sides of a plastic bottle would anchor the propeller inside the rim to produce a ducted thrust vortex. The pearl allows the rubber band to counter rotate the cycloidal wing while allowing the bearing to spin the propeller too. A thin dowel can hold the rubber band to the back.
synchro1
Sodhart glues the soda straw to the top of the soda can. It glues to the craft stick the same way. The pearl acts as a friction gear set between two short lengths of plastic soda straw! This is a master stroke of gimmickery! The pearl ball is actually standing still while both sides are rotating in opposition. A quick and dirty Barrel Gear! The problem with the Pepsi can is that the spiraling fins are catching a reverse back wash from the propeller. Minimized drag and Máximum  vortex thrust achieved when channeled through the center!
This is a "Cyclo Gyro" not a helicopter. We can fashion a couple of cool spiral fins cut from a second bottle. This experimental design will fly ten times better with the propeller inside the rim of the cycloidal gyro wing.
synchro1
Propellers inside the ring:
synchro1
I wrote Siddheath Creations on YouTube and suggested positioning the propeller inside the cone, and he replied and said he will try it! So let's wait for the next upgraded version!
synchro1
Ducted 3 blade fan is ideal!
