Help me understand complementary push pull amp
Started by nix85, March 09, 2021, 05:29:27 AM
nix85
I got trouble understanding how EXACTLY you imagine half bridge creating AC.
(Let's ignore the fact that you cannot just recreate the missing halfcycle and call it HiFi)
Now you are mentioning resonance and inductors.
Let's first get some basics out of the way...
We all know no electrons pass through a cap, but a changing electric field, displacement current..
We also know reactance of the cap is XC= -1/2πfC
So, higher the frequency and capacitance, more it looks as if cap is not there.
We also know in purely capacitive or inductive circuit voltage and current are 90° out of phase.
Any changing waveform passes "through" a cap, be it pulsed DC or AC.
So halfsinewave passes through a cap as easily as a whole sinewave does.
In other words, when the halfsine ends, with slight delay, voltage would pass through the cap leaving it uncharged.
So let's bring in resonance. If we are talking LC tank instead of a cap alone, then it depends if it's in series of parallel.
Series LC tank at resonance is short circuit, in parallel open circuit..
So, how exactly is other half of the sinewave produced.
AlienGrey
It sounds like you dont experiment  a capacitor is an insulator so how can it pass currevt ?
it charges and discharges it's size demnds on its time and frequency and how it's charged
Also if the cap is in series your DC content is lost.
Also if you bias a semiconducter on its on off slope your moving its DC swing in your circuit.
nix85
Quote from: AlienGrey on March 10, 2021, 04:28:06 AM
I do experiment and build but you clearly don't know the basics.
You don't know what displacement current aka capacitor current is, google it.
"Wire has inductance" sooo? Unless it's coiled inductance is negligible.
Everything i wrote is COMMON ELECTRONIC KNOWLEDGE.
Everything you crossed and called wrong is correct.
"It depends on slope bias set up", no it doesn't, you can't recreate the missing halfcycle and call it HiFi.
All changing voltage waveforms indeed pass through a cap, be it pulsed DC or AC... even pulsed DC squarewave signal will pass through a cap at the moment of the change.
Back to school.
antijon
The first image that you posted wouldn't work. As it is nothing would happen on the neg half cycle.
Just saying it's more likely that they forgot to add the label for -VCC at the bottom rail.
Otherwise, you could replace the "ground" at the load with the center tap of a voltage divider. e.g. if you had 12V from VCC rail to bottom rail, when the top transistor closes the load would see 6V+ from VCC to center tap. When the bottom transistor closes the load would see 6V- from center tap to bottom rail. (Don't really know if this would work because I don't do electronics but it seems feasible in my head lol)
nix85
They did not forget it is implied and most often symbolized that bottom is also "ground", that is, Vcc-.
Of course "ground" does not always have to be Vcc-, it's just a circuit wide reference point.
Here is the first diagram on google images for push pull amp
Looking at these diagrams one would conclude that during negative halfcycle current flows from ground to ground, lol.
