Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 78 Guests are viewing this topic.
NdaClouDzzz
Don't be silly, Brad!
Even if what you are talking about is real and not some word-play trickery, the entire point of me using that water example was so everyone would know what MY definition of OU is. And here you are taking it literally. But please Mr. Tinman, by all means show us your talent!🤣
tinman
Quote from: NdaClouDzzz on April 04, 2021, 04:01:50 AM
What it means is that your example has nothing to do with OU,but everything to do with a total waste system.
You know as well as i do that the energy from the water running out of the drum can be used to put a portion of that very same water back into the drum,thus meaning that more water will run out of the drum than the volume you first put into the drum,without bringing any extra water in from outside the system.
So lets see==
The water runs out of the drum through a ram pump.
66% of the water spills onto the ground,and 34% gets pumped back into the drum.
So the total volume of water that runs out of the drum exceeds that which you first put into the drum by 34%,without bringing any more water in from an outside system.
Quoteme using that water example was so everyone would know what MY definition of OU is.
As you can clearly see,your definition of OU is wrong.
Brad
NdaClouDzzz
Bravo, Brad. I commend you on your skillful spin tactics.
But MY example has nothing to do with YOUR example, other than water!
In MY example, take a one gallon jug filled with exactly one gallon of water and, with your hand, empty that one gallon of water directly into another container and measure how much water there is. No more than ONE gallon of water! No trickery, no word-play, just ONE gallon of water!
That is MY definition of what an ou argument and demo would entail. If you perform that exact test and you pour out more than ONE gallon of water, then brother, you got magic in your hands! ;D
Note: I do not talk about the ENERGY that you can get from the water running out of the jug because we would then have to address the energy that was expended to put the water IN the jug!
Mish
Interesting question.  There is a big difference between O.U. and perpetual motion. Yes, after searching day and many nights i found and made a wheel that proves over unity. I am currently working on making it perpetual,  but for me i am content knowing after hundreds of measurements the sum total of forces always measures more positive torque than negative torque. Here is a short video i made that shows only 2 arms that are using 2 weights. On the left the weight on the left is furthest from the hub as on swings down and the other up they swap at the 4:30 and 10:30 positions.
https://youtu.be/VYzHNcu0eTk
conradelektro
I have built several OU devices, but I will not tell you how they work. Whenever I disclosed an OU device, it stopped being OU.
Greetings, Conrad
