Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 55 Guests are viewing this topic.
https://www.pbs.org/tesla/ll/ll_todre.html
In this detailed, futuristic vision he described a means of tapping the sun's energy with an antenna.
Beside "water power",later !
the tower :
For his new construction project, Tesla acquired land on the cliffs of Long Island Sound. The site was called Wardenclyffe. By 1901 the Wardenclyffe project was under construction, the most challenging task being the erection of an enormous tower, rising 187 feet in the air and supporting on its top a fifty-five-ton sphere made of steel.
Beneath the tower, a well-like shaft plunged 120 feet into the ground. Sixteen iron pipes were driven three hundred feet deeper so that currents could pass through them and seize hold of the earth.
"In this system that I have invented," Tesla explained, "it is necessary for the machine to get a grip of the earth, otherwise it cannot shake the earth.
It has to have a grip... so that the whole of this globe can quiver."
https://www.google.com/search?rlz=1C1AVFC_enPT930PT930&q=Quiver+meaning&sa=X&ved=2ahUKEwj77rL4m-DwAhVM1xoKHT2TC5gQ1QIwHXoECA0QAQ&biw=1366&bih=574
it is not a passive system and more than only an antenna !
https://www.mouser.com/blog/tesla-fails-to-power-the-world-without-wires
Tesla also demonstrated his scheme in Colorado Springs, CO, where he had built a "magnifying transmitter" that lit incandescent electric lamps placed as far as 300 feet away from it.
In which year he demonstrated the " magnifying transmitter" ? Showing which effect ? Sourced by ?
Attention : chronos/time table !
https://www.pbs.org/tesla/ll/ll_todre.html  1901 view,
Then on December 12, 1901, the world awoke to the news that Marconi had signaled the letter "S" across the Atlantic from Cornwall, England to Newfoundland. Tesla, unruffled by the accomplishment, explained that the Italian used 17 Tesla patents to accomplish the transmission. But Morgan began to doubt Tesla.
                                        Marconi's system not only worked, it was also inexpensive.
1905 view ,
to
https://www.researchgate.net/publication/320335847_Geoengineering_Tesla's_Wireless_Power_Transmission -1924 view
https://www.pbs.org/tesla/ll/ll_wendwar.html
In 1931 Tesla announced to reporters at a press conference that he was on the verge of discovering an entirely new source of energy.
What set Tesla's proposal apart from the usual run of fantasy "death rays" was a unique vacuum chamber with one end open to the atmosphere. Tesla devised a unique vacuum seal by directing a high-velocity air stream at the tip of his gun to maintain "high vacua." The necessary pumping action would be accomplished with a large Tesla turbine.
and 2021 chronical review !
https://thelivingcoach.wordpress.com/category/tesla/
Tesla's breakthrough realization of the nonlinear dynamics of multi-frequency oscillations in the infrasonic range was seeded during experimentation with a pocket-sized electro-mechanical oscillator in 1888.
The unusual circumstances of this astonishing experiment were briefly given to a reporter from the New York World-Telegram in 1935, describing Tesla's accidental production of localized earthquakes and acoustic levitation of multi-ton generators and other heavy metal equipment at his East Houston St. laboratory:
I was experimenting with vibrations. I had one of my machines going and I wanted to see if I could get it in tune with the vibration of the building. I put it up notch after notch. There was a peculiar cracking sound... I knew I was approaching the vibration of the steel building. I pushed the machine a little higher. Suddenly all the heavy machinery in the place was flying around. I grabbed a hammer and broke the machine. The building would have been down about our ears in another few minutes. Outside in the street there was pandemonium. The police and ambulances arrived. I told my assistants to say nothing. We told the police it must have been an earthquake...
That experience inspired Tesla's invention of the Gravity Motor, tapping the limitless power of acoustic resonance by generating standing waves within a drum. Tesla's finest, most suppressed invention was discussed in a psychic reading for Thomas T. Brown given by trance channel Edgar Cayce on March 8, 1928 in Chicago, at the LaSalle Hotel, a luxurious palace hotel conveniently located across the street from the Masonic Lodge, a well known establishment of the American-Nazi industrialists (Reading 4665-1):
stivep
Translation of  my response to AlienGrey into Russian:
Quote from: AlienGrey on May 23, 2021, 10:29:59 AM
Когда все, что требуется, это стоячая волна? Не могли бы вы объяснить, как стоячая волна генерирует полезную мощность?
- когда  доктор Корум доставляет энергию в свою башню Tx Tesla, между Верхним конденсатором и землей создается стоячая волна.
Когда положение верхнего конденсатора настроено на желаемый угол Брюстера, энергия, захваченная стоячей волной, поступает
на двухмерную границу раздела земля / воздух, однако это можно регулировать не только точным подъемом верхнего конденсатора,
но и фазирующими катушками. любая из методик вызывает точно такой же эффект.
Цель состоит в том, чтобы энергия стоячей волны входила в границу раздела-интерфейс, без отражения и преломления.
Требуется больше геометрии и математики, а не только угол Брюстера, поскольку волна Ценнека в режиме TM
на интерфейсе синтезируется в соответствии с уравнениями Максвелла.
link- TM Mode
Но требуется еще один фактор.
Катушка Тесла должна видеть нагрузку с другой стороны интерфейса !!!
Если нет, - то энергия поступит в интерфейс без потерь, онa будет просто сидеть там, ожидая любой нагрузки, которую онa может найти,
-и которая соответствует требуемому характеристическому сопротивлению нагрузки и условиям приема.
Вот почему онa намного более эффективнa, чем традиционные электрические медные линии высокого напряжения,
доставляющие энергию от электростанции в традиционной электрической сети.
И когда я говорю об извлечении энергии из волновода Шумана - это наша CE - процессы в точности такие же.
Пространство между ионосферой и землей содержит стоячую волну !!!!!
Стоячая волна не генерирует никакой энергии.
Это просто состояние, в котором энергия удерживается внутри стоячей волны из-за несоответствия импеданса.
https://en.wikipedia.org/wiki/Standing_wave
Почему вы все время показываете картинку взрывного детонатора, изобретенного по приличию - "decorum"
Это доктор Корум (не"decorum"), и это башня Визива Тесла.
У нас есть Илья, который может не понимать, о чем мы говорим, и попросил включить визуальное представление / визуальный опыт рассматриваемых явлений..
look here: https://overunity.com/18815/has-anyone-here-constructed-an-overunity-system-that-works/msg557946/#msg557946
Russian translation is here: https://overunity.com/18815/has-anyone-here-constructed-an-overunity-system-that-works/msg557959/#msg557959
Парни: пробуйте поймать меня кое на чем, что является вздором
-  на техническoй или научнoй чепухе
-  на глупых или обманчивых словах
-  на техническом или научном   бредe... каком то.
Я бы хотел это увидеть
Wesley
stivep
Quote from: AlienGrey on May 23, 2021, 11:59:23 AM
next question is regarding 1/4 wave phenomena
as that would fall on the energy peek. Perhaps you could explain that pls
I may not understand fully your question so sorry if it is not exactly want you expected:
QuoteA quarter-wave impedance transformer, often written as λ/4 impedance transformer,
is a transmission line or waveguide used in electrical engineering of length one-quarter
wavelength
(λ), terminated with some known impedance.
It presents at its input the dual of the impedance with which it is terminated.
https://en.wikipedia.org/wiki/Quarter-wave_impedance_transformer
The λ/4 transformer is the other way around;
it is a pre-determined length and the termination is designed to produce the required impedance match.
QuotePeak demand, peak load or on-peak are terms
describing a period in which electrical power is expected to be provided
for a sustained period at a significantly higher than average supply level.
but I'm sure that it is not you wanted  to ask me for.
You are possibly alluding to: the highest amplitude of the wave  in  one-quarter
wavelength
(λ) resonator.
Answer: The maximum amplitude is seen
when impedance of the load e.g antenna / e.g  Tesla Coil
matches the impedance of the output of Tx( transmitter)
or  in case of the Rx:
-matches the impedance of the input of Rx receiver antenna and connected to it  input of the receiver.
We often use 1/4 wave resonating antennas and coils  as it is convenient
to us to build much shorter structure of an antenna or much  smaller Tesla Coil.
look here for exact  answer:
how much gain does a 1/2 wave dipole have over a 1/4 wave dipole?
https://forums.qrz.com/index.php?threads/1-4-wave-vs-1-2-wave-antenna.232457/
But  if you are talking about EMP I can't provide the answer for you here on the forum
As this is  very much real  or "more than real" for Zenneck wave . This kind of  questions  must not
be answered or no answers must be provided  to unknown reader.!!!
https://en.wikipedia.org/wiki/Electromagnetic_pulse
Wesley
AlienGrey
Sure EMP is something else that distroys all yer test gear isn't it ?
There are so many circuits (one on colors thread) where
the guy appears to be collecting the peek of the 1/4 wave amplitude, just  how it works is a logic
thing i have gone all through his posts on the subject but it appears to be a secret squirrel thing
regards
Ilya Tsimbaluk
Now we are not talking about the fact that energy can be transmitted through the air. Although there is a question of efficiency. The question is, do you have a device. which gives it or not. If not, then it makes sense to change the rhetoric and deal with physics.
