Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
solotraveler
We should look into history for a second about the electric motor. 1880 or so, started the mass production of electric motors. Most likely some improvements have been made, but we could definitely say that,  from 1899 we still have the same coil, a wire around a piece of metal. I call it a wire stick. If we ask the engineering community could things be improved, the usual answer would be no - you can't create energy from nothing. This is what they were taught and most likely no effort was made to change this statement.  When asking other individuals the same question, the answer would be - whatever we see, it can and it must be improved. For me, both of those groups are 100% right. Everybody sees what they believe.
Axial motors are pushed now. Big companies are snatching them on the market, trying to be first. If we look inside of these motors, can we see something new? Or, is it still an 1899 wire stick with new clothing.
Another good example is linear labs from Texas. They are creating a vortex tunnel or something to that effect. The coils within the tunnel are pushing with all 4 sides, but there is still a problem with heat. Heat and inefficiency always go together. This would be a good indicator that they didn't remove the old thinking from their innovation. The same problems persist.
When I have to give my opinion, I always look for one thing - are they using the same old coil or they have learned how electricity works and then incorporated that knowledge into their design. This would be the only indicator as to whether they will have a future or not. What I am trying to say is, the only way forward, is to see electricity for what it is and move ahead with the new knowledge.
Best Regards
pauldude000
Quote from: solotraveler on January 11, 2022, 10:21:16 PM
Best Regards
The concept of DC motors have been around since the early 1800's Faraday was the first to demonstrate in 1821 a very simplistic electromagnetic motor (not to be confused with much earlier electrostatic motors, which do not work on magnetism). In 1828 the first modern style (stator/rotor/commutator) configuration of DC motors were invented. Concerning AC, many try hard to attribute it to Ferraris in 1885, but not even. Tesla developed the concept of AC electricity while still in college (and was laughed at as perpetual motion) but sold the concept of AC generation to Westinghouse, already having working models of generators, and three different styles/types of AC motors which he patented in 1888. He invented the AC generator, the transmission system, AND the motor that ran on it. Tesla had one huge problem though, in that he was a huge show-off. He demonstrated stuff to crowds often before he ever applied for patents. For instance, you may not know that legally Tesla is now the official inventor of Radio, as per a fairly recent court case. I have no doubt Ferraris went to one of his demonstrations, just like Marconi did, if you get my gist. That is also why Ferraris is never mentioned in the debates between Tesla and Edison concerning DC as a usable effective public power source. Tesla loved attention...
Tesla is responsible for two-phase and multiphase motors, from non self-starting, to self starting, to shorted shunt "modern" designs, as well as owning the patents for rotating magnetic fields and numerous means for making them, which is almost never mentioned. Tesla was a very prolific inventor, that scientists play down as much as humanly possible.
That is all not even mentioning any of his high voltage high frequency work.
The problem is that the methods for determining efficiency are still the same notions used at the turn of the last century - specifically heat. The concept originated in thermodynamics, but it has never been asked to my knowledge, whether a conversion to heat can be called efficient. Many chemical processes for instance are not endothermic, which demonstrates that heat is not the end all be all of energy, as work is done in ANY chemical reaction, even if no heat is produced. If you turn to electric power, current efficiency standards are still based against heat, which makes no logical sense at all. The problem is that the entire system is entrenched in academia. The principle from thermodynamics called the conservation of energy is true and does apply to other forms of energy other than heat, but it has a scope on which it applies which is dubious, in that it only applies to the notion of a closed system according to its postulates. Also, the base notions being applied to the concept are from 1800's scientific thought.
We know now that matter can appear and disappear from spacetime, which violates energy neither being created nor destroyed by old concepts, except that the system isn't closed. They call those particles "virtual" to get rid of the supposed violation. The antiquated system did not envision spacetime being a universal energy source -- the probable source of the mysterious zeropoint energy discovered at 0 degrees Kelvin, or any possible energy source other than those known at the time for that matter. Not to knock the men of the day either, since they just simply did not have the data we have now. With E=MC^2 scientists around the world should have opened their collective eyes, as that is how much energy is ultimately available even in matter.
To put things into perspective, did you know C-4 is flammable? It will burn, and still not explode. However, which will give me more energy, burning it, or detonating it? There is a discrepancy there, and it is not simply time. Both are molecular reactions, but you get far less energy with burning, as the process is not nearly as complete. Basically, it smokes when burnt, and that material going up as black greasy smoke is wasted energy In 1800, they would have burnt it to heat a volume of water, ignoring any and all energy wasted to the environment. When you are heating a beaker of water with a flame, you ignore the fact that very little energy is getting to the water compared to what is being wasted. Some of the heat is radiated to the sides, while a large portion hits the glass. Of the heat that hits the glass, only a portion is absorbed, and the rest slides up and around the glass, escaping into the air. The water itself is radiating heat to the glass container and the air as well -- more wasted energy.
To effectively measure efficiency using heat, you would have to contrive a system THAT IS CLOSED. Specifically, the system could get no heat or energy from any other source, nor could it lose heat or energy while being measured. That is a tall order. It MIGHT be possible, but I doubt it, because who knows what quantum effects are going on.
Now, as then, they marginalize the concept of over-unity or COP>1 by referencing it stupidly, yes stupidly, as perpetual motion. It is stupid because the concept involves something remaining in motion, with no extra energy causing it to stay in motion, for perpetuity. We can now list numerous things that move spatially, with no extra energy added to cause it to remain so, for perpetuity. These things are INTENTIONALLY disallowed, such as magnetic fields, gravity fields, electric fields, electron orbits among numerous others, black holes wormholes, etc., etc., etc., e freaking cetera.
The concept of over-unity is itself a complex case of intellectual sophistry.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
onepower
Paul
QuoteIn 1828 the first modern style (stator/rotor/commutator) configuration of DC motors were invented. Concerning AC, many try hard to attribute it to Ferraris in 1885, but not even. Tesla developed the concept of AC electricity while still in college (and was laughed at as perpetual motion) but sold the concept of AC generation to Westinghouse, already having working models of generators, and three different styles/types of AC motors which he patented in 1888. He invented the AC generator, the transmission system, AND the motor that ran on it.
Indeed and the same false perceptions about oscillating/alternating systems still persist even today.
Most still believe any oscillation/alternation must always sum to zero therefore the energy transfer must be zero which is false. This is because the majority of people still don't understand the concept of energy.
QuoteNow, as then, they marginalize the concept of over-unity or COP>1 by referencing it stupidly, yes stupidly, as perpetual motion. It is stupid because the concept involves something remaining in motion, with no extra energy causing it to stay in motion, for perpetuity. We can now list numerous things that move spatially, with no extra energy added to cause it to remain so, for perpetuity. These things are INTENTIONALLY disallowed, such as magnetic fields, gravity fields, electric fields, electron orbits among numerous others, black holes wormholes, etc., etc., etc., e freaking cetera.
I agree...
As I like to put it... give me one example of anything anywhere not in perpetual motion.
Nobody can answer the question and it becomes pretty obvious most have no idea what there talking about. It's kind of comical because all the experts I put the question to always end up looking like a deer stuck in someone's headlights. They have literally no idea why they came to believe something which is obviously false. Even worse, it represents a complete failure to apply even basic logic and reasoning to a relatively simple problem.
Question: Is perpetual motion possible or impossible?.
Reasoning: Do we have any proof or real world examples of something not in perpetual motion?.
Answer: Oh shit, no we have no examples therefore everything must be in perpetual motion.
Here is another logical argument...
1)Energy cannot be created or destroyed only transformed.
2)All energy relates directly to the motion of something on some level be it particles or waves.
3)Therefore since energy cannot be created or destroyed neither can the motion which represents energy.
4)All energy as motion which was ever present in the universe must still be present because it is always conserved.
5)Either energy as motion is always conserved or the conservation of energy cannot hold true.
AC
pauldude000
AC, you hit that nail directly on the head, so to speak.
Paul Andrulis
