Temporary placeholder for Dally and friends builders bench
Started by ramset, April 06, 2021, 07:19:58 PM
ramset
Thanks Grandma
ramset
Getting more serious ( re: local conditions and protocols for testing /safely .
As mentioned many times by the builders... these techs stir things up in local area !
I imagine that's a good thing , but precautions are mandatory!
https://www.overunityresearch.com/index.php?topic=3926.msg94066;topicseen#msg94066
Shared with gratitude and respect
Chet K
Thanks Grandma
stivep
 Great work  Itsu you have done over  the years
Thank You for that. I don't want this to sound esoteric.
You and me  we are fallowing certain complex direction.
I took as priority to concentrate on what energy comes from before  conversion and you are investigating workability of the device
that wasn't conformed independently as  working.
Just because  it is related to Tariel Kapanadze  I suggest to do the simple test.
Take The fancy Tariel/Ruslan coil   place it vertically, add    conducting telescopic mast having on the top capacitor on the top.
Place it on  aluminum  foil 20m long  and  at the end  of that coil place regular Tesla coil acting with  adjustable top capacitor acting  as a receiver.
The frequency   of resonance of both should not be more than 52MHz. At best 1.8MHz but than  foil length must be longer so you are not in  near field.
See if you are able to send energy from point A to B.
Example:
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg558491/#msg558491
Watch videos.
The difference between videos done by that PhD and me is that he had not much idea  what he is doing and what Zenneck Wave is about.
changing elevation of top capacitor makes the trick but now  it would be you trying differently winded  coil  in  the same condition.
The reason for  that coil to look like that is lowering its resonance frequency by  CW CCW sections.
Dr Corum  made it clear in his patent from 1987
In proposed arrangement  we fulfill conditions for  the interface  - conducting media and  Air  above it acting as dielectric.
Wesley
ramset
Stivep
Thanks for contribution
Certainly interesting and .......
Here the open source builder/researchers continue the hunt
https://www.overunityresearch.com/index.php?topic=3926.msg94254;topicseen#msg94254
Respectfully
Chet K
Thanks Grandma
ramset
Thanks Grandma
