"Hydrogen Technology" LLC
Started by lancaIV, May 02, 2021, 08:03:18 AM
Sergh
I assume that a very strong ultrasound of a relatively low frequency is needed. An unusually strong ultrasound that can grind stones into dust through cavitation. Therefore, the YouTubers' experiments with relatively weak ultrasound were unsuccessful.
Found something on YouTube to show what I mean:
https://www.youtube.com/watch?v=ONFk6PZ2nNY
https://www.youtube.com/watch?v=zCT2CyDz7cA
https://www.youtube.com/watch?v=4k7XK2Rl5fc
https://www.youtube.com/watch?v=Bu0BLf_fZNY
The presence of ultrasound alone does not give overunity. Gas production is low. Some kind of catalyst is needed in a general sense.
Many ideas,experiments : dis-/advantage/-s !?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=20040812&CC=US&NR=2004156779A1&KC=A1
https://www.lenr-forum.com/forum/thread/5435-the-usherenko-effect-very-strange/
https://slidetodoc.com/super-deep-penetration-a-k-a-usherenko-effect/
https://www.lenr-forum.com/attachment/3626-usherenko-sdp-inrc-nti-pdf/
https://patentauction.com/search.php
https://patentauction.com/patent.php?nb=11103
https://patentauction.com/patent.php?nb=14562
https://patentauction.com/patent.php?nb=13320
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=20050609&CC=US&NR=2005121367A1&KC=A1
https://en.wikipedia.org/wiki/Windhexe
https://worldwide.espacenet.com/publicationDetails/biblio?FT=D&date=19830518&DB=EPODOC&locale=en_EP&CC=EP&NR=0078799A1&KC=A1&ND=4
Hence, one can say the REACTOR TO TRANSMUTE THE MATTER is an apparatus to produce calories. For example, if 2,000Kcal (two thousand kilo/calories) is introduced in the REACTOR it will be possible to multiply these calories by 100 (a hundred), 1,000 (a thousand) and even 100,000 (a hundred thousand) according to what it is chosen to be used. The only condition to have a progressive multi plication of the calories without problems is to provide a cooling apparatus like the one used in combustion engines during operation.
The results achieved with the REACTOR TO TRANSMUTE THE MATTER are of great importance. Using a mixture of dihydrogen oxide and ethylic alcohol,equally proportioned in weight, as fuel to feed the REACTOR, it was identified at the outlet of the REACTOR (before its admission in the engine) 33 (thirty three) different gases,such as: ARGON,ALUMINIUM, COBALT, MOLYBDENUM, TECHNETIUM, RUTHENIUM, RHO DIUM, PALLADIUM, LANTHANUM, THULIUM, ASTATINE, AMERICIUM and CURIUM. In additon, at the outlet of the exhaust pipe it was observed 46 (forty six) different gases. Among the se gases it was registered: HYDROGEN, HELIUM, LITHIUM, BERYLLIUM, ALUMINIUM, CHLORINE, TECHNETIUM, RUTHENIUM, RHODIUM, BARIUM, LANTHANUM, POLONIUM, PROTACTINIUM, AMERICIUM, CURIUM, BERKELIUM and HAHNIUM.
Three other gases which are in the group could not be identified according to the PERIODIC CHART OF TH-ELEMENTS; Their numbers are 109, 111 and 131.
It is interesting to remember that the PERIODIC CHART OF THE ELEMENTS classifies only till element No. 105.
                       EP0078799 (A1) ― 1983-05-18
2021 : https://www.sigmaaldrich.com/technical-documents/articles/biology/periodic-table-of-elements-names.html
Sergh
"Oh no."
Ultrasound - for creating dynamic pressure and temperature differences, and for "catalisator" degassing . LENR and transmutation are unlikely.
https://patents.justia.com/inventor/harry-w-kompanek
transducer use in "Hydrogen Technology"-application "cited documents"
https://patents.justia.com/patent/4038348  atomizer/vaporizer function
The transducer is in an "unloaded" condition (High Q); therefore, when the fuel strikes the surface it is immediately atomized or vaporized.
similar https://www.unicusmagazine.com/pioneers2003/firestorm.htm spark for plasma
dis-/advantage !?
https://en.wikipedia.org/wiki/Plasma_(physics)
https://en.wikipedia.org/wiki/Nonthermal_plasma
Catalysis[edit]Atmospheric pressure non-thermal plasma can be used to promote chemical reactions. Collisions between hot temperature electrons and cold gas molecules can lead to dissociation reactions and the subsequent formation of radicals. This kind of discharge exhibits reacting properties that are usually seen in high temperature discharge systems.[22] Non-thermal plasma is also used in conjunction with a catalyst to further enhance the chemical conversion of reactants or to alter the products chemical composition.
Among the different application fields, there are ozone production[23] at a commercial level; pollution abatement, both solid (PM, VOC) and gaseous (SOx, NOx);[24] CO2 conversion[25] in fuels (methanol, syngas) or value added chemicals; nitrogen fixation; methanol synthesis; liquid fuels synthesis from lighter hydrocarbons (e.g. methane),[26] hydrogen production via hydrocarbons reforming[27]
from hydrogen to fusion process
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=winfield+salisbury&CPC=&IC=&Submit=Search
