Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
0 Members and 45 Guests are viewing this topic.
nix85
John Worrell Keely 40 LAWS OF VIBRATION (COSMIC VIBRATION)
1. Law of Matter and Force:
Coextensive and coeternal with space and duration, there exists of all matter: these are in a state of constant vibratory motion, infinite in extent, unchangeable in quantity the initial of all forms of energy.
2. Law of Corporeal Vibrations:
All coherent aggregates when isolated from like bodies, or when immersed of confined in media composed of matter in a different state, vibrate at a given ascertainable pitch.
3. Law of Corporeal Oscillation:
All coherent aggregates not isolated from like bodies, oscillate at a period-frequency varying with the tensions that augment and diminish the state of equilibrium.
4. Law of Harmonic Vibrations:
All coherent aggregates are perpetually vibrating at a period-frequency corresponding to some harmonic ratio of the fundamental pitch of the vibrating body; this pitch is a multiple of the pitch of the atomole.
5. Law of Transmissive Vibraic Energy:
All oscillating and vibrating coherent aggregates create in the media in which they are immersed, outwardly propagated concentric waves of alternate condensation and rarefaction, having a period-frequency identical with the pitch of the aggregate.
6. Law of Sympathetic Oscillation:
Coherent aggregates immersed in a medium pulsating at their natural pitch simultaneously oscillate with the same frequency, whether the pitch of the medium be a unison of any harmonic of the fundamental pitch of the creative aggregate.
7. Law of Attraction:
Juxtaposed coherent aggregates vibrating in unison, of harmonic ratio, are mutually attracted.
8. Law of Repulsion:
Juxtaposed coherent aggregates vibrating in discord are mutually repelled.
9. Law of Cycles:
Coherent aggregates harmonically united constitute centres of vibration bearing relation to the fundamental pitch not multiples of the harmonic pitch, and the production of secondary unions between themselves generate pitches that ate discords, either in their unisons, or overtones with the original pitch; from harmony is generated discord, the inevitable cause of perpetual transformation.
10. Law of Harmonic Pitch:
Any aggregate in a state of vibration develops in addition to its fundamental pitch a series of vibration in symmetrical sub-multiple portions of itself, bearing ratios of one, two, three, of more times its fundamental pitch.
11. Law of Force:
Energy manifests itself in three forms; Creative the vibrating aggregate: Transmissive, being the propagation of isochronous waves through the media in which it is immersed; Attractive, being its action upon other aggregates capable of vibrating in unisons or harmony.
12. Law of Oscillating Atomic Substances:
Coherent atomic substances are capable of oscillating at a pitch varying directly as the density, and inversely as the linear dimensions from one period of frequency per unit of time to the 21st octave above, producing the creative force of Sonity, whose transmissive force (Sound) is propagated through the media of solids, liquids, and gases, and whose stated effect (Sonism) produces attractions and repulsions.
13. Law of Sono-thermity:
Internal vibrations of atomic substances and atomic molecules are capable of vibrating at a period-frequency directly as their density, inversely as their linear dimensions, directly as the coefficient of their tension from the 21st to the 42d octaves, producing the creative force (Sono-thermity), whose transmissive force (Sono-therm) is propagated in solid, liquid, gaseous, and ultra-gaseous media, statically producing adhesions and molecular unions, or disintegration, according to the Law of Harmonic Attraction and Repulsion.
14. Law of Oscillating Atoms:
All atoms when in a state of tension are capable of oscillating at a pitch inversely as the cube of their atomic weights, and directly as their tension from 42 to 63 octaves per second, producing the creative force (Thermism), whose transmissive force (Rad-energy) propagated in solid, liquid, and gaseous ether, produces the static effects (Cohesion and Chemism) on other atoms of association, or dissociation, according to the Law of Harmonic Attraction and Repulsion.Scholium: Dark radiant heat begins at absolute zero temperature, and extend through light, chemical rays, actinic rays, and infraviolet rays, up to the dissociation of all molecules to the 63d octave.
15. Law of Vibrating Atomolic Substances:
Atoms are capable of vibrating within themselves at a pitch inversely as the Dyne (the local coefficient of Gravity), and as the atomic volume, directly as the atomic weight, producing the creative force (Electricity), whose transmissive force is propagated through atomolic solids, liquids, and gases, producing induction and the static effect of magnetism upon other atoms of attraction or repulsion, according to the Law of Harmonic Attraction and Repulsion.Scholium: The phenomena of Dynamic Electricity through a metallic conductor and of induction are identical. In a metallic conductor, the transmission is from atom to atom, through homologous interstices, filled with ether, presenting small areas in close proximity. In crystalline structures, heat, which expands the atoms, by twisting them produces striae, increases the resistance, etc. Between parallel wires and through air the induction takes place from large areas through a rarefied medium composed of a mixture of substances, whose atoms are separated by waves of repulsion of various pitches, discordant to electric vibrations; the said atoms sympathetically absorb the vibrations and dissipate from themselves, as centres, concentric waves of electric energy which produces heat and gravism.
16. Law of Oscillating Atomoles:
Atomoles oscillating at a uniform pitch (determined by their uniform size and weight) produce the creative force Atomolity, whose transmissive form, Gravism, is propagated through more rarefied media, producing the stated effect upon all other atomoles, denominated Gravity.
17. Law of Transformation of Forces:
All forces are different forms of Universal Energy unlike in their period-frequency, merging into each other by imperceptible increments; each form representing the compass of 21 octaves. Each form or pitch may be transformed into an equivalent quantity of another pitch above or below it in the scale of 105 octaves. The transformation can occur only through its static effect, developing vibrations of harmonic pitches above and below their fundamental vibration, or developing with juxtaposed aggregates, resultant and difference, or third order, as the case may be.Scholium: A table of the intervals and harmonics of the normal harmonic scale will indicate the ratios in which the transformation of forces will occur.
18. Law of Atomic Pitch:
Atoms have each a different and definite pitch, at which they naturally vibrate.Scholium: Atomic pitch is determined directly from its simple spectrum.Scholium: Atomic pitch is determined by computations from its associate spectrum with all other atoms, as in known spectra.Scholium: Atomic pitches are more important working data then atomic weights; tables of atomic pitches must be precise.
19. Law of Variation of Atomic Pitch by Rad-energy:
The higher harmonics and overtones of projected rad-energy are of a pitch sufficiently high to cause the atom to expand: by causing the atomoles to vibrate systematically the same influence will cause the atom to contract, and thus by changing the volume, atomic pitch is varied.
20. Law of Variation of Atomic Pitch by Electricity and Magnetism:
Electricity and Magnetism produce internal vibration in the atom, which are followed by proportional changes in volume and, therefore, pitch.
21. Law of Variation of Atomic Pitch by Temperature:
Atoms in chemical combination oscillate with increasing amplitude directly as the temperature, and simultaneously absorb overtones of higher harmonics, producing expansion of volume and diminution of pitch.Rule: The gradual approach of the temperature of harmonic combination can be observed by mutually comparing superimposed spectra; chemical combination commences when the fundamental lines of each spectrum bear harmonic ratios by linear measurement.
22. Law of Pitch of Atomic Oscillation:
Atoms not isolated and in a state of tension between forces that oppose and increase the equilibrium oscillate bodily at a pitch that is a resultant of the atomic weight, atomic volume, and tension.
23. Law of Variation of Pitch of Atomic Oscillation by Pressure:
The frequency of atomic oscillation increases and diminishes inversely as the square of the pressure.
24. Law of Variation of Atomic Oscillation by Temperature:
The force of cohesion diminishes inversely as the square of the distance the atoms are apart, and the force of the chemical affinity diminishes in the same ratio. Heat increases the amplitude of the oscillations in a direct ratio to the temperature of the natural scale. Scholium: New thermometers and accurate thermometric tables, on the natural bases, wherein doubling the temperature doubles the pitch of the transmissive energy, are required. Such a table of temperature will bear natural relations to atomic weights, pitches, specific heats, chemical affinities, fusions, solubilities, etc., and will disclose new laws. One table for each must be constructed.
25. Law of Variation of Atomic Oscillation by Electricity:
The electric current destroys cohesion and chemical tension directly as square of current in amperes, inversely as the resistance in ohms, inversely as the chemical equivalent, and conversely as the coefficient of the difference between the freezing and volatilizing temperature of mass acted upon.
26. Law of Variation of Atomic Oscillation by Sono-thermism:
Diminishes the tensions directly as the quantity of heat developed and in antithetical proportion to the harmonics absolved.
27. Law of Chemical Affinity:
Atoms whose atomic pitches are in either unison, harmonic or concordant ratios, unite to form molecules.Corollary: When two atoms are indifferent, they may be made to unite by varying the pitch of either, or both.Scholium: This necessitates the construction of tables representing variation of atomic pitches by temperature, pressure, etc.Scholium: Tables of all harmonics and concords, and harmonics founded upon a normal harmonic scale, are equally essential.Scholium: Optical instruments may be made to measure pitches of energy.
28. Law of Chemical Dissociation:
If the pitch of either atom, in a molecule, be raised or lowered: or, if they both be unequally raised of lowered in pitch until the mutual ratio be that of a discord; or, if the oscillation amplitude be augmented by heat until the atom are with the concentric waves of attraction, - the atoms will separate.
29. Law of Chemical Transposition:
New molecules must be harmonics of the fundamental pitch.
30. Law of Chemical Substitution (too complex for brief statement).
31. Law of Catalysis:
The presence of harmonics and discords.
32. Law of Molecular Synthesis and Combination (Organic):
The molecular pitch must be a derived harmony of the radicals. Scholium: Reconstruction of electric units to represent pitches and amplitudes.
33. Law of Chemical Morphology:
The angle of crystallization is determined by the relation between the molecular pitch of the crystallizing substance to the vibration-density of the liquid depositing it.
34. Law of Atomic Dissociation:
Overtones of high rad-energy pitches produce separation of the atomoles and recombinations among the atomolic molecules of the atoms.
35. Law of Atomolic Synthesis of Chemical Elements:
Harmonic pitches of atomolity produce association of etheric-atomolic particles to form atoms: the kind of atom is determinable by the pitches employed.
36. Law of Heat:
Atoms under the tension of chemical combination oscillate with an amplitude directly as the temperature, inversely as the pressure, and as the square of the specific heat. Diminishing the pitch of oscillation inversely as the square of the distance of the atoms apart, and simultaneously increasing the vibrating pitch of the atom by absorption of overtones and higher harmonics.
37. Law of Electro-chemical Equivalents:
An atom vibrates sympathetically under the influence of electric energy, such undertones of which are absorbed as are a harmonic or harmony of the electric pitch; the amount of energy absorbed being directly as the arithmetical ratio of the undertone of the fundamental electric pitch.Scholium: A table of elector-chemical equivalents on the normal basis will indicate the electrical conditions and amount of chemical change.
38. Law of Cohesion:
The cohesion between atoms diminishes directly as the square root of the pressure and temperature, and as the square of electric intensity.
39. Law of Refractive Indices:
A table of the refractive indices of substances indicates their molecular pitch; and in connection with crystalline form the phase of molecular oscillation.
40. Law of Electric Conductivity:
Electric energy is transmitted through homogeneous bodies with a completeness in direct proportion as the atoms are more or less perfect harmonics of the electric pitch, but not as all through substances whose atoms are discordant to the electric pitch; also through molecular substances, when their resultant notes are harmonics of the electric pitch,-the transmissions being inversely as the temperature, directly as the density diminished in proportion to the amount of crystallization, and inversely as the cube of the dyne, also directly as the reciprocal of the magnetic intensity. As we believe the above statement to be of priceless value to the world, in proportion as they are comprehended, we offer no apology to our readers for introducing so many technicalities, but publish them in the expectant hope that some struggling seeker after scientific verity may find in them a key to the solution of many perplexing mysteries.
https://translatedby.com/you/john-ernst-worrell-keely-s-forty-laws-of-sympathetic-vibratory-physics/original/
Definitions to aid in understanding Keelys' Laws of Sympathetic Vibration
ATOMOLES:
elementary units of matter uniform in size and weight, and which exist in solid, liquid, gaseous, and isolated forms.
ATOMS:
are multiple combinations of atomoles, and they also exist in solid, liquid, gaseous, and isolated forms.
SIMPLE MOLECULES:
Text
are formed by the union of two atoms of the same kind.
COMPOUND MOLECULES:
are unions of two atoms of dissimilar kind.
COMPLEX MOLECULES:
are unions of molecules with other molecules or atoms.
PITCH:
is the relative frequency of vibration.
VIBRATION:
is the rhythmical motion of a body within itself.
OSCILLATION:
is a rhythmical recurring translatory movement.
TRANSMISSIVE ENERGY:
is rhythmical motion of condensation and rarefaction produced by the vibrating or oscillating body in the medium in which it is immersed.
ATTRACTION:
is the mutual approach of aggregates caused by concentrated waves of harmonic energy, tending to move in line of least resistance, by becoming the centre of one series of concentric waves instead of two or more series.
HARMONY:
is the simultaneous vibration of two or more bodies whose harmonics do not produce discords, and whose fundamental pitches are harmonics of the lowest pitch, or are a unison with the resultant notes or overtones, or undertones, of any two or more of them.
AETHER:
is an atomolic liquid 986,000 times the density of steel.
ELECTRICITY:
is the oscillation of the atomoles of an atom.
INDUCTION:
is the transmissive force of the electric vibration in aether.
MAGNETISM:
is the mutual attraction of juxtaposed bodies vibrating at unison or harmonic electric pitches.
GRAVITY:
is the mutual attraction of atomoles.
GRAVISM:
is the transmissive form through a medium of atomoles in the fourth state, or a medium composed of atomolini.
ATOMOLINI:
are ultimate units of atomoles, and when in a liquid state are the media for the transmission of gravism. The illimitable divisibility and aggregation of matter is a logical sequence.
These 40 laws have been hidden away for over 85 years. We believe the time is long past for the free sharing of such information among all interested parties.
https://svpwiki.com/Keelys-Laws-of-Being
file:///C:/Users/beatr/Downloads/KeelyandHisDiscoveries_10034791.pdf       400 pages !
http://www.rexresearch.com/keely/keely.html
https://www.lockhaven.edu/~dsimanek/museum/keely/keely.htm
E. Alexander Scott :
The wire, he guessed, was a hollow tube transmitting air pressure to the water chamber. To counter this suggestion, Keely cut a ways into the wire with a file to prove it solid. But Moore surreptitiously picked up a scrap piece of similar wire in the workshop and later found that it did have a very fine, hollow center.
https://www.lockhaven.edu/~dsimanek/museum/keely/secret2.gif
https://www.youtube.com/watch?v=ZGiviT-C_oY
https://www.youtube.com/watch?v=1QW1-q3NklE
how much the diameter of the compressed air delivering hollow tube for 1 KW,5 KW and more rotative "compressed air" engine output ?
My philosophy frame: not theology,also neither scientology nor  Theosophy : simple Teleology
and  http://www.georgehart.com/virtual-polyhedra/synestructics.html ,  Buckminster Fuller his frame
https://patents.google.com/patent/US3937426A/en
https://patents.google.com/?inventor=Peter+J.+Pearce
Sincere
OCWL
p.s.: https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990318&CC=DE&NR=19740299A1&KC=A1
An example is given of a reciprocating engine with a swept volume of 1.766 ccd, piston diameter 3.5mm, which produces 70 watts at 500 rpm.
10 000 RPM Infinitysav/ 500 RPM Haeberle ( https://rudolf-diesel-medaille.de/preistraeger/  awarded)
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=4331904&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
        ALTRUISMUM
The only need for this protection application for me is to prevent this knowledge from being lost with my death and it should be food for thought for others.
nix85
Lanca links..
Levitation or Gravity Control
from Snell Manuscript, 1934
In the spring of 1890 Keely succeeded in raising the metal weight composing his airship model, by means of a force still unknown to science. One of his friends stated "When he has gained as perfect control of it as we now have over steam, airships weighing thousands of tons can easily traverse the highways of the air."
"He has gained control of the mysterious polar current to that extent that he has been able to exhibit on the thirds or molecular graduation of the propellor of his airship, 120 revolutions per minute, and on the sixths or atomic graduation, 360 revolutions per minute. He still has the etheric field to conquer."
Keely says "By exciting the metallic mass composing a navigator of any given weight, it may be suspended and propelled. The vibratory neutral negative attraction evolved will bring it into perfect commercial control by keeping it in sympathy with the earths polar stream." This is why he sought to find the sympathetic connection between luminous ether, or inflowing celestial streams, and the radiating or terrestrial streams, which, by their interaction "solar tensions against terrestrial condensations" cause the polar current and its kindred phenomena.
While he used "sympathetic negative attraction" for running machinery, he sought to use for aerial navigation, another force, a "negation" of "sympathetic negative attraction" or the same force that regulates the recession of the planets from each other. This is probably simply polar propulsion, although he terms this elsewhere as gravity.
"The power of the terrestrial propulsive and celestial attractive is to lift and of the celestial propulsive and terrestrial attractive is to descend. Certain polar or antipolar vibrations can intensify either of these qualities so as to cause either of them to predominate. Intensifying the celestial will cause a metallic mass to rise with a speed proportionate to the concentration of the dominant bearing on the negative thirds of its mass chords, thereby inducing high neutral radiation together with celestial attraction."
"An airship of any number of tons weight can, when my system is completed, float off into space with a motion as light as thistledown, or with a velocity out rivaling the cyclone. With the force of corpuscular bombardment its movements can be as varied as is necessary for commercial use at any desired elevation and at any speed." (The Snell Manuscript)
Levitating Gyroscopes
John Ernst Worrell Keely, 1894
"A small instrument, having three gyroscopes as a principal part of its construction, is used to demonstrate the facts of aerial navigation. These gyroscopes are attached to a heavy, inert mass of metal, weighing about one ton. The other part of the apparatus consists of tubes, enclosed in as small a space as possible, being clustered in a circle. These tubes, represent certain chords, which were coincident to the streams of force acting upon the planet, focalizing and defocalizing upon its neutral center. The action upon the molecular structure of the mass lifted was based upon the fact that each molecule in the mass possessed a north and south pole, - more strictly speaking, a positive and negative pole, - situated through the center, formed by the three atoms which compose it. No matter which way the mass of metal is turned, the poles of the molecule point undeviatingly to the polar center of the earth, acting almost exactly as the dip-needle when uninfluenced by extraneous conditions, electrical and otherwise. The rotation of the discs of the gyroscopes produces an action upon the molecules of the mass to be lifted, reversing their poles, causing repulsion from the earth in the same way as like poles of a magnet repel each other. This repulsion can be diminished and increased according as the mechanical conditions are operated. By operating the three discs, starting them at full speed, then touching two of them, so as to bring them, according to the tone they represented by their rotation, to a certain vibratory ratio, the weight then slowly sways from side to side leaves the floor, rising several feet in the air, remaining in that position, and as the discs gradually decrease their speed of rotation the weight sinks to the floor, settling down as lightly as thistledown. Where one molecule can be lifted, there need be no limit as to the number in a structure that may be operated upon as easily as one. The vessel in contemplation, the aerial navigator, will be over two hundred feet long, over sixty feet in diameter, tapering at both ends to a point, made of polished steel, and will be capable of being driven under the power of depolar repulsion, at the rate of three hundred miles an hour. It can be far more easily controlled than any instrument now in use for any phase of transit. Another very remarkable feature connected with this system of aerial navigation, is that the vessel is not buoyed up or floated in the air through the medium of the air, so that if there were no atmosphere it would float just as readily; hence, under mechanical conditions most certainly capable of production, involving massive strength of resistance to interstellar vacuity this can be made capable of navigating even the remote depth of space, positions between planets where polarity changes being controlled by other adjuncts of concentration for that purpose.
Safely enclosed within this structure, a man possessing the chemical knowledge these new laws give, with sufficient supply of material from which to make oxygen, by the enormously increased rate of speed attained by such navigator where atmospheric friction is avoided, the time occupied in traveling from one planet to another would be amazingly brief, and one can travel to other planets in this system of worlds as easily as the same ship could navigate the depths of the ocean.
The great obstacle hitherto preventing the solution of this problem has been the strength of structure needed under conditions above presented. With this knowledge of matter, the size of structure is unimportant; the heaviest can be as easily controlled as the lightest."
From Dashed Against the Rock,, by William Colville, 1894.
https://www.svpvril.com/svpweb10.html
Is John Keelys work only based by fake,under-/overestimated,
https://en.wikipedia.org/wiki/John_Ernst_Worrell_Keely
or to find in Physics today with the expression " ..... effect" by others their name `!
"40 phenomen laws (if ....,then ... ,published 1893 !?), hypo-/thesis
how restricted in reality their functional order validity,when one/more law space is over-/inner lapped ,compressed ?
                                                  linear or turbulent/chaotic
                                                     laws or effect orders
At first : Nature Biology to Nature Re-/Engineering ,called Bionics or Tribology
up (in chaos) down in dimension https://en.wikipedia.org/wiki/Nanotribology
and https://en.wikipedia.org/wiki/Triboelectric_effect
https://phys.org/search/?search=triboelectricity&s=0
https://phys.org/news/2021-06-dynamics-contact-electrification.html
                     Re: Reactive Current - Parallel RCL
                           Reactive flow/fluid - Paralel /Seriell RCL Analogon
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3330899&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
[0012]
The invention is based on the knowledge that there is an analogy between electrical engineering and fluid mechanics.
[0013]
This consists in the fact that an electromagnetic field around an arbitrarily bent wire-shaped conductor and a flow field around an arbitrarily shaped vortex thread are described by the same law,
        Biot-Savart's law.
The quantities "increase in magnetic field strength" and "increase in speed" therefore correspond to one another.
Since magnetic field strength can be concentrated by winding a current-carrying conductor into a coil, an increase in speed can also be achieved in fluid technology by winding a vortex thread into a coil.
If you arrange several whibs rotating in the same direction so that their axes lie on a circle, they will rotate around the center of the circle as a result of mutual induction.
The induction increases with the number of vortices. The winding speed increases and the wedged threads approach the shape of closely spaced ring vortices.
The velocity field that these ring vortices induce inside them creates the desired concentration effect.
Citation End
To this it would be helpfull to read about Torricelli ( unit TORR ) and Toribio Bellocq its oeuvre and confirmated fluid/electric AC current analogy !
https://www.youtube.com/watch?v=AfCyzIbpLN4 and related 4:15+ https://www.youtube.com/watch?v=suIAo0EYwOE
the Tesla turbine inner IMPELLER linear structure  with Infinitysav inner curvative IMPELLER structure and
centipetal and/ or centrifugal forces in-/decrease effect ,by structure geometry !
Sincere
OCWL
p.s.:  Musical Dynasphere  https://svpwiki.com/Musical-Dynasphere
        https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=meta+c&IN=dinnan&CPC=&IC=&Submit=Search
https://en.wikipedia.org/wiki/Sympathetic_nervous_system
https://en.wikipedia.org/wiki/Autonomic_nervous_system
https://en.wikipedia.org/wiki/Parasympathetic_nervous_system
https://en.wikipedia.org/wiki/Enteric_nervous_system
RNA and DNA intercommunication language ?
https://en.wikipedia.org/wiki/Neurotransmitter      https://en.wikipedia.org/wiki/Neuron
https://en.wikipedia.org/wiki/Fantasy_(psychology)        https://en.wikipedia.org/wiki/Reality
Fantasies are typically associated with scenarios that are statistically implausible or impossible in reality .
https://www.healthline.com/health/hallucinations
5 sin/s organ/s : basic and/or ? (8-12 ) http://www.anthroposophie.net/peter/
https://biologie-lernprogramme.de/daten/html/basiskonzept_information/daten/html/23_Uebersicht_zu_Reizen_und_Sinnesorganen.html
in the case of "internal stimuli", overlaps with the hormonal system
Do You eat cornflakes,no name or "KELLOGGS" ?
https://www.britannica.com/topic/Kellogg-Company
patients at Dr. Kellogg's Battle Creek Sanitarium https://www.youtube.com/watch?v=S93aiPRym4o
        https://www.youtube.com/watch?v=P1sl_NOOK-U
stupidity or humans their behaviour mimikry or both in one ?        https://www.youtube.com/watch?v=BX4qWdhkPjo
natural "wellness" medicine each morning ? ;)  https://www.youtube.com/watch?v=rcGnWA2w4t8
