Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
Jo-EL
@nix85
Ich weiß das Du nix ( = NICHTS ) weisst = I know that you know nothing ( from this thuff )
Ich spiele nicht ich forsche ! = I don't play, i am in reseach !
Und ja, Englisch ist nicht meine Muttersprache = And yes, english is not my native language.
Darüber hinaus antworte ich nicht mehr auf so Scheiß Bemerkungen !!!
nix85
Quote from: stivep on July 11, 2022, 10:01:49 AM
science rejected ether that's why you can't:"
-list  its properties,
-explain its interaction nor provide any credible links.
"Science" you refer to is fundamentally a joke.
You are either amazingly blind or a shill, there is no third option.
Ether is absolute certainty, and as i said, it's of multiple types, as it is written
in Etidorhpa:
""Do you say that the atmosphere is composed of substances unknown to man?"
"Yes; several of them are gases, and others are qualities of space condition, neither gas, liquid, nor solid. One particularly interferes with light in its passage. It is an entity that is not moved by the motion of the air, and is unequally distributed over the earth's surface. As we ascend above the earth it decreases, so it does as we descend into it. It is not vapor of water, is neither smoke, nor a true gas, and is as yet sensible to man only by its power of modifying the intensity of light. It has no color, is chemically inactive, and yet modifies the sun's rays so as to blot objects from view at a comparatively small distance from a person on the face of the earth. That this fact is known to man is evident from the knowledge he possesses of the difference in the power of his organs of vision at different parts of the earth. His sight is especially acute on the table lands of the Western Territories.""
And something i already shared on the forum...
A little bit from Oahspe telling few important things well known in occult circles, that light we see is created in the atmosphere and that there are various strata, plateaus of the vortex surrounding the Earth, these are the 7 astral shells i talked about.
Earth, Needles in the Atmosphere, and Plateaus.
When Jehovih condensed the earth, and it became firm and crusted over, there rose up from the earth heat and moisture, which continue to this day. But Jehovih limited the ascent of the substances going upward, and the boundary of the limit of moisture was the same as the clouds that float in the air; and the heat was of similar ascent. And while the moisture and heat rise upward, they are met by the etheric substance of the vortex of the earth, and the moisture and the gases of the air assume the form of needles. On the side of the earth facing the sun the needles are polarized and acting, driving forth, which is called light; but on the face of the earth opposite from the sun the needles are in confusion, and this is called darkness. Jehovih said: So that man may comprehend the structure of the belt that holds the earth, I will give him a sign high up in the air. And Jehovih caused the vapor in the firmament to be frozen and fall to the earth, white, and it is called snow. For the snowflake shows the matrix in which it is molded. Jehovih said: Let this be a sign also, that even as heat and moisture rise up from the earth, so are there representatives of all things on the earth which have also evaporated upward, and all such things rise up to the level of density that is like themselves, every one to its own level, and they take their places in the strata of the vortex. These are called plateaus; or spheres, for they surround the whole earth. Some of them are ten miles high, some a thousand, some a hundred thousand or more miles. And all these spheres that rotate and travel with the earth are called atmospherea, or lower heavens.
As I made a limit to the ascent of clouds, so I made a limit to the places of the different kinds of substances in atmospherea; the more subtle and potent to the rim, and the more dense and impotent nearer to the earth.
According to the condition of these different plateaus in atmospherea, whether they are near the earth or high above, |65| so shall the spirit of man take its place in the first heaven; |66| according to his diet, desires and behavior, so shall he dwell in spirit on the plateau to which he has adapted himself during his earth life.
Earth and Plateaus of Lower Heaven. E, Etherea; B, periphery of the earth's vortex. This line was called by the ancients the Bridge of Chinvat.* All within this area is called Atmospherea. The center circle is the earth; land mass is black; O, the ocean. 1, 2, 3, represent atmospherean plateaus on and near the earth. The O, O, O, with a line through it, represent atmospherean oceans.
*Note that to make the earth, etc., apparent, this Chinvat line is not to scale. That is, were Chinvat drawn in actual proportion to the shown size of the earth, the B line would be drawn some 30 of earth's diameters distant from the center of the earth."
There is no question if there is an ether,
Aspden effect is relatively well known in OU community, i read skeptical forums,
they tried to explain it away by the fact that heated ball bearing will have less
resistance :) I am sure you will favor this "explanation"
http://exo-science.com/aspden.html
http://villesresearch.com/ether.html
Then you have Etheric Rainmaking with Trevor James Constable
Watch it, slowly, fully, attentively. Then you will have to decide,
either it's a hoax or there is ether.
https://www.youtube.com/watch?v=MjeUhQJp5WE
How long are you gonna live in silly denial of the obvious.
QuoteThere is no terms/ meaning- "True Physics"
science rejected to recognize God that's why you can't:"
-list God's properties,
-explain God interaction nor provide any scientific credible physics/al links
-science explains processes and doesn't keep it secret as oppose to unrecognized by it "God"
What you call God is not something outside you nor is there such thing as "outside".
You are IT, and it's easy to know it if you withdraw attention...
...beyond linear time (and space), beyond mind, it takes no effort, it's already there,
silent background, still awareness, isness, being, it's not a philosophy or a belief,
it is the source of all, the driving power, the only true reality. But forget about
spiritual realization just by withdrawing from linear time, ultimate bliss is not
attained easily. Most of us at best see but glimpses of it from time to time.
"Science" that does not approach from the God-side, from source-downward, even
if it stumbles at certain effects will always be extremely limited and flawed to the core.
___________________________________________________
ether/ eather , Overunity, Perpetual motion
-all of it doesn't exist  and you can't:
-explain its interaction nor provide any credible links,
-you can't even explain why you are calling science
opposing that nonsense
It all exists and properties are well known and explainable by those in the know,
surely not to you.
I know it surely exists and that it's of various kinds and that it creates light and
heat, influences weather, affects what we call weight, is closely related to vitaly etc.
It is a whole new (old) science, only TRUE science.
Look how he sleazily insists on "credible links". He knows well this stuff is far
removed from what is commonly called "credible" or "peer reviewed", but in
vain, ether IS.
QuoteIf Ether doesn't exist and you can't provide credible scientific info/proof than "etheric streams" can't exist too.
As long as you deny the ether you will live in denial of true science.
Quotelook here: Deterministic switching of ferromagnetism at room temperature using an electric field https://www.nature.com/articles/nature14004
Random unrelated article that does not even mention frequency of any kind.
~Frequency from 7 Hz to 17 kHz is where the access to that energy is, due to low losses  of EM energy in the interface and in TM mode.
Phh. Losses depend on the core, in electrical steel they become
too high above 500Hz yet in ferrite they are low even at many MHz.
What you say is nonsense, has no relation to reality. Danger is some noob might
fall for your deception. How many have you lead into the hertzian death, how many lights have you destroyed. God knows.
QuoteYour problem nix85 is in :
- your statements without supported by science explanation:
    Dog barking on the street  is possibly making some unexplained statements too. ( joke)
Wesley
Your problem, stivep, is you are as limited as a horse with blinders
https://en.wikipedia.org/wiki/Blinkers_(horse_tack)
What you call "science" is the bottom side of the two sided coin and that bottom
side is in the shadow and covered with filth. The upper side, the side closer to
the sunlight, which is blemish and dirt free is totally beyond your grasp.
Horse runs after a carrot cause he knows not he will never reach it that way (joke?)
stivep
Please understand - I'm not your enemy.
Quote from: nix85 on July 11, 2022, 10:14:28 AM
Jo-EL < Broken english aside,
You can find only shortcuts / abbreviations. e.g: "physics/al links" for word: "physical"
Show me please in my text from above  any broken English phrases ?
there's another one playing the i know it
you don't games, ironic and comical.
I assume you meant: - "your"  instead of word "you."
or  there is missing word "are"
in phrase:
you don't games, - "are" ironic and comical.
for average reader here, my explanation and questions are precise and concise.
where is your physics based response to the "God" question?
where is your physics based response to ether/ eather , Overunity, Perpetual motion
where is your physics based response denying "Frequency from 7 Hz to 17 kHz quote."
please provide scientifically recognized links to the articles conforming your revelations.
No single answer to the previous post was provided by you, not even one.
and your last response is by that "ironic and comical."
please correct me if I'm wrong?
Wesley
nix85
Quote from: Jo-EL on July 11, 2022, 12:02:34 PM
@nix85
Funny, i like how you describe yourself cause you indeed know nothing.
You can't even spell research, back to square one.
nix85
Quote from: stivep on July 11, 2022, 12:28:47 PM
Please understand - I'm not your enemy. You can find only shortcuts / abbreviations. e.g: "physics/al links" for word: "physical"
Funny, i was clearly addressing the other guy, not you.
in phrase:
No, i meant it as it's written, "playing the "i know it you don't" games"
Again, i was not addressing you there, as for your explanation and questions
they are limited and flawed, you deny ether and many true natural phenomena.
Wesley
You always play the same silly game with everyone, claiming they did not answer
your supposed questions.
I addressed all the key points, IT IS YOU who again dodges all the points i made
and tries to derail the conversation. Aspden effect, Trevor James Constable etc
etc etc, address this.
Focus on facts, scientifically, objectively.
You deny ether, etheric streams.... you are wrong as wrong can be.
BTW Where then do you imagine Kapanadze's excess energy comes from
from nearby radio tower maybe or some other hertzian source
