Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
Electrical power (P, in Watts) is composed of voltage (V, in Volts) and current (I, in Amps).
The formula is P= V × I.
In german : Huestel,huestel ! ::)
DC is EE power    P= V × I
AC is EE power  P= V × I ?  Hertz -function ? Only tension or current or both processing ?
Puls is EE power P= V × I ? by which duty cycle ?  AM and FM modulation,PWM
electrical engineering history :
1 Daniel cell represents 1 Volt DC source
100 Daniel cells represents 100 V DC source
+ distribution losts = 110-115 Volt DC source
DC electricity = current and tension positive
AC distribution = positive DC =  DC x 2 = 220/230 Volts by 50/60 Hertzian cycles
AC = positive tension phase   + positive current phase
        negative tension phase  + negative  current phase
mono-/poly-phase
1 V x A DC =      ? V x A AC       = each in mechanical Watt           linear/curvativ  active/reactive
1 V x A AC =     ? V x A DC       = each in mechanical Watt          curvativ/linear  reative/active
electrical power a. DC b.AC c. pulsed(current on/off)  in mechanical power ? torque x linear/rotative rpm movement ?
                                                          EE set theory : EE algebra,geometry
alan
Power is joules per second. Voltage = joule / coulomb. Current = coulomb / second.
Voltage x current = joules / coulomb x coulomb / second = joules / second  :)
stivep
Quote from: lancaIV on June 08, 2021, 08:46:23 AM
Wesley,I am not nix85,but related #8   1 in and more than 1 out (conditionized !)
https://phys.org/news/2012-03-efficiency.html
OCWL
QuoteLED's efficiency exceeds 100%
That is possible the same way as COP>1 in refrigerators.
https://www.quora.com/How-does-the-cop-of-refrigerator-is-greater-than-1
and that's is why looking at local phenomena is important .
But that is not overunity.
Wesley
Quote from: stivep on June 08, 2021, 11:48:14 AM
Wesley
reversible thermo-cryo dynamic cylce : dB(noise,sound,loud,oscillations,......) to electrical energy
overunity is not a common used scientifical expression because " mental weakness" from scientist side,to have and show
the      OU-q.e.d. stage and by world-wide peers review and process application and confirmation
        for science primates:
let the expression "over-unity efficiency " as evolutive step from https://phys.org/news/2012-03-efficiency.html
be "equivalent same"  in physics target (theory)and physical(practizising)  result as "overunity"
        "But that is not"  overunity ,
this discuss with the researchers, Parthiban Santhanam and coauthors from MIT, have published their study in a recent issue of Physical Review Letters.
stivep
Quote from: lancaIV on June 08, 2021, 11:52:24 AM
Yes you right.
that is why I'm waiting for  the response from nix85  curing  my "mental weakness"
I'm waiting for him to "have and show" ....
...........no... not his private parts...
Dear nix85  show me OU you are talking about please...
Wesley
