Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
Force = Mass * acceleration
Work = force * distance moved  unit: newton meter or joule or Work = Mass * Gravity * Height
Work = Change in Energy
Power = work / time = force * displacement / time = force * velocity
Power (hp,watt) = work(ENERGY)/time aka time rate of energy transfer
Energy = Power x Time
On deeper level there is no positive or negative "particles", every"thing" is made out of neutral bubbles of consciousness, they appear as tiny voids in the ether, there is no detectable rotation or inner content in them, they are just tiny voids, koilon = ether in greek meaning hollow...
These neutral bubbles make up male and female "atoms" (which would correspond to some subatomic particle probably smaller than quarks). These are positive and negative but their only difference is the direction of flow of NEUTRAL bubbles.
Vitality globules, lifeforces and etheric atoms
Fig. 1. Lifeforce & vitality
According to Leadbeater (1927) the Sun sends out several of forms of etheric energy, for example lifeforce and vitality. The lifeforce seems to be capable of occupying several different kinds of etheric form and most commonly it adopts an octahedron, made of four atoms arranged in a square, and one central atom constantly vibrating up and down. Sometimes it uses exceedingly active little molecule consisting of three atoms. The vitality globule consists of seven atoms, arranged like the atoms in lifeforce, except in a form of hexagon instead of a square. In all of these forms the central atom is in rapid vibration at right angles to disc plane of other atoms, springing up from it to a height greater than the diameter of the disc, and then sinking below the disc to an equal distance, repeating this motion several times in a second.
Fig. 2. Feminine etheric atom
The term "atom" used here refers to etheric atoms. There are two kinds of etheric atoms, positive (masculine) and negative (feminine). In the positive atom the lifeforce flows (counterclockwise) from the fourth dimension to the physical world and in the negative atom the lifeforce flows (clockwise) from the physical world to the fourth dimension. The force flows in from the wider end, causing a heart like shape. It spirals within and around this atom in closed loops. The atom is spinning upon its own axis and it has a regular pulsation, a contraction and expansion, like the pulsation of the heart.
The Sun radiates vitality to all levels. The vital force enters some of the physical atoms, immensely increases their activity and makes them animated and glowing. When vitality wells up within atom, it endows it with an additional life, and gives it a power of attraction so that it immediately draws around it six other atoms which it arranges in a hexagonal form. These globules are conspicuous above all others which may be seen floating in the atmosphere, on account of their brilliance and extreme activity. While the force that vivifies these globules is quite different from light, it nevertheless seems to depend upon light for its power of manifestation. In brilliant sunshine this vitality is constantly welling up afresh, and the globules are generated with great rapidity and in incredible numbers, but in cloudy weather there is great diminution in the number of globules formed, and during the night, the operation is entirely suspended.
http://www.villesresearch.com/ether.html
Learning that vitality atom is hexagonal in shape it may not come as surprise in whole universe hexagonal grid, or honeycomb core material is used for healing.
Good Morning,nix85 ,
we are similar,but not same ! And I do not base my research on unidentified foreigners,without experiments !
Am I against the Infinitiysav their claims : C.O.P. 100 excluded controler consume ? Why shall I ?
https://overunity.com/18289/lallemand-heat-pump/  C.O.P. 25
Different input/output ratio : surface/speed/rotation/pressure et cet. ergo process parameters !
C.O.P. 100 : https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19991224&CC=JP&NR=H11356033A&KC=A
                                                    in vacuuo
Sincere
OCWL
alan
Quote from: alan on June 17, 2021, 09:10:19 AM
distance = speed * time
distance ( and displacement)  for itself(ves are)  is metrical,without tempus ,a length
distance as route ( velocity," speed has no direction" ,but  in " velocity has direction" )  :
speed = distance/time            speed x time = distance
miles/ph  = miles x hour         mph    x h       = m ?!
                                                    mph   /   h       = m !?
per = means  divided m/h but miles x ( = times or multiplied)  hour = mh or m•h
% per centum (one nullus) (2 nullus= per mille ) also known in street traffic as " promille"  ;) Alc in blood
Syntax and right algebraic sign mathematical and lingual for not school/Uni/workplace Crash-course !
Helps white and blue collar relationship and understatement and bilateral satisfaction !
alan
with a couple of elementary units and its derivatives, we can describe much of classical physics.
position=x
v=dx/dt
a=dx2/d2
jerk=dx3/d3t=da/dt
mass=m  momentum=mv
force=ma
yank=m
jerk=m*da/dt
work e=force*x
power w=force*v
charge=q
current i=dq/dt
volt=e/q
e= v*q
p=v*i=e/q*q/t=e/t
capacitance=q/v
inductance=v /(i/t)
