Would like to Submit a PDF with regards to a Gravity Assisted Device
Started by GravityAntiGravity, June 28, 2021, 07:49:50 PM
Do any members want to receive research data on GAGA Engine
Do any members want to receive research data on GAGA engine
1 (50%)
Do any members request build info
1 (50%)
Total Members Voted: 2
GravityAntiGravity
I am currently working on the GAGA 3 motor.  It is also known as the HOPE motor, Help Our Planet Earth.  I am currently seeking 3RD Party testing from a local University.  Current model shows results that are over 40% over baseline and 21% over results of the GAGA 2 model.  The device uses 2 energies from the ethers, gravity and magnetic repulsion.  I am including a photo of the GAGA 3.
e2matrix
What is the power input ( volts x amps ) in watts versus the power output in watts?
kajunbee
Quote from: e2matrix on November 06, 2021, 12:13:15 PM
Meters show roughly 85 watts in and 19 watts out.
GravityAntiGravity
5.9 watts input to GAGA 3 lowers wattage required to turn wind turbine by 29 watts with similar total resistance.
Total Seconds to run 10 watt/per hour for wind turbine is Avg. 400 seconds without GAGA 3engaged.   Total Seconds to use 10 watts/hour with GAGA 3 motor engaged 648 seconds.
lota
