Maybe some NEW info?
Started by Johan_1955, November 12, 2021, 07:03:06 AM
kampen
[color=var(--ytd-video-primary-info-renderer-title-color,var(--yt-spec-text-primary))][size=var(--ytd-video-primary-info-renderer-title-font-size,var(--yt-navbar-title-font-size,inherit))]MAMAMATAY ang PETROLEUM, COAL at BATTERY sa BAGONG PINOY INVENTION!!!
https://www.youtube.com/watch?v=r51TdNPA55s
I do not understand the technology behind this project.
[/size]
What is it?[/font][/size]
Can somebody explain this.[/font][/size]
sm0ky2
Quote from: onepower on December 05, 2021, 12:35:16 PM
Another sensational device :)
The internals look similar to the Kapanadze/Ruslan devices.
These boys aren't fooling around with LED's and are talking kW of power...
I think 2022 is the year all this comes out and goes mainstream. Too many people are replicating the technology all over the world.
AC
It looks simple,
asymmetrical transformers, paired through a 4-way flux converter
which appears to be 1:1 ratio on all 4 coils, arranged in an 'X' between the
two larger coils
sm0ky2
From there it is stored in VERY large super capacitors
ramset
Edit
Sorry for off topic
Will start new topic if appropriate
Respectfully
Chet
Thanks Grandma
sm0ky2
It's difficult to narrow down a precise topic here,
Nigel's technologies could be broken down into several threads
or even its' own category, if everything checks out.
I would love to start working on some of his other things
but i'm kind of engrossed in this 'Ion Harvesting' thing.
There are some questions i would like to answer
and see really how far we can push this.
Taking a step back, what we have is:
A high-impedance return circuit (through the air / environment)
and a low impedance diode circuit, which 'steals' the ionic current
causing a potential across the diode, and generating photons.
(when LED is used, if only diode used only heat is created)
If we match the impedance of the first diode circuit with a second
but in the opposite direction
The ionic current returns through the secondary diode path
instead of following the high-impedance return path.
This causes a potential across the second diode, generating more photons.
Question 1: How many LEDs can be connected in series here?
(theory) The more series LEDs, the higher voltage/potential required to light them all.
Question 2: How many LEDs can be connected in parallel here?
(theory) The more parallel LEDs, the higher current required to light them all.
Is there an upper limit to either of these conditions?
Or can we draw infinite Ionic Current?
We know that after a dozen or so LEDs (tested up to 42)
the air around the ion source becomes ionized (anions?)
forming ozone and charging anything that touches it
upwards to 100-110kV
The opposite occurring at the anode
(the air charges + (Ions), and anything touching it goes -)
And yes this is intuitively backwards, until you understand that
the ionic current flows in the other direction.
This is where the separation between current theory and ion flow theory
come into play.
This circuit only makes sense when analyzing it using ionic flow theory.
Which allows analysis (superposition) across multiple (sometimes reversed) current loops.
Here we see that the same current is flowing in both directions through our circuit.
Also that opposite potentials are forming at both ends.
Result: +0.003A + -0.003A = 0A
           +2V. + -2V = 0V
This is why we cant meter it
With only 1 diode, we still have an opposite potential
through the high-z return path
Again : no measurable voltage
However - there is 3ua current (@0v) through the primary circuit.
now you ask yourself how can we have current with no voltage?
You dont. You have 2v AND -2v, flowing in both directions at the same time.
3 microamps in one direction and something like picoamps in the other.
Why is current flowing in both directions?
Ion Theory tells us that as we draw eV from the source (a - metal):
the source becomes (+) deficit from its' natural state, and has a tendency to
take on charge from the environment.
Conversely, as we send eV to the sink (a + metal):
the sink becomes (-) deficit from its' natural state, and has a tendency to
Of course the atmosphere is full of both + and - ions and can freely supply this deficit.
However, when there is a lower impedance path, the two metals themselves can
rebalance each other. (minus whatever became photons and heat crossing the diodes)
The energy consumed to generate photons and heat, is then replenished from the air.
Conclusion 1:
                   There appears to be dual-current in both directions through the circuit and an
additional third (high-z) ionic current formed through the air between sink and source.
Conclusion 2:
                    Voltage and Current in all 4 directions are equal and opposite,
resulting in 0 (net) power.
Conclusion 3:
                    Converting the ionic current into heat and photons allows us
to extract energy from a self-replenishing stage in the process.
Resulting in a Zero Point Energy Source
