4 Million Tera Watts from 3 car batteries
Started by indigo22, November 27, 2021, 06:08:37 AM
indigo22
For the building of the coil i used a pvc pipe aircore drilled a hole in the midle for the collector 50 50 to create ac. Laminated copperwire same as john bedini. For i the transistors i recomment the irf's cheap and quick and allot of power. Irf540 or irf 840 or 860 just check the datasheet pdfs.
The plasma cel batteries need refueling sow what i did is pored some clearcoat epoxy into the ganz after it has been charged and let it dry. After 6 years the drycell battery with gans witch produses normaly 0.6 per cel volt went up to 1.4
indigo22
The prototype tvk coil started out with the 2 wires collectors and the j bedini bifilair  wires on top pulsed them and created 10 times overunity. Now you use 2 coils singlewire pulse. Make sure you use diodes on your output from the arduino to the transistor. I dont use drivers sow maybe someone can make it better let me hear i am all ears.... not eyes..i am sorry... :'(
indigo22
I had a voltcraft ossiloscoop dso if you look good on the internet you can reprogram the ic and make them quicker from 100 Mhertz to 200 Mhertz 8)
indigo22
Also try out capacitors instead of diodes witch heat up, they also only allow the current 1 way ;D
indigo22
When i was stil running my lab and not hiding this was my end results
