RESSURECTED TINMAN NEW INVENTION.
Started by seychelles, December 18, 2021, 10:54:04 AM
captainpecan
Here is what I have so far. I made it so I can adjust pretty much everything and expand if needed. Everything is still to loose and the Neo's are still yanking everything together while I'm working with the gap. I also have only worked with one set of magnets so far so all the pull is on one side as well. I don't have any numbers to report yet until I get things tightened better. I will hopefully strengthen everything up this weekend and make it more reliable to get some numbers. I will keep at it and update as soon as I can. A lot to do still, but it's starting to come along.
synchro1
Quote from: captainpecan on January 08, 2022, 04:54:04 AM
Good solid design! The Russian "Magnet Shield" videos are the best. It should come as no surprise if you produce the same COP.
Floor
This looks like another cat is out of the bag.
Way to go guys.
captainpecan
Just another small update. I'm getting there. I've got things tightened up pretty good now. Now the only issue I have is that the magnets still like to slide side to side on the slick surface of the metal. Was hoping the strength of the magnets would hold them down. But they are so strong, it's a bit hard to control them without gluing them or something. I'm working on it. If I get the gap closer, they break free from their seated position and jump to the rotor. But everything is tight and not flexing anymore. I am using N52 1/2 by 1/2 cylinder magnets. The metal I used is 1/8 inch by 3/4 inch steel.
I can't seem to get back into my old youtube account. I just made a new one. Here is a tiny video of the gap and rotor. As you can see, the magnets still want to slide a tad.
https://youtu.be/FnJ4QljQpK4
