Ionosphere Oscillation Ever Attempted?
Started by Eighthman, December 20, 2021, 09:50:45 AM
onepower
Eighthman
QuoteI also think......'free energy' (however defined) could hide in some small fundamental mistake made when modern science was still 'new'.
Indeed and Beaty hit on part of the solution...
QuoteThe two papers above provide a solution. If an atom behaves as an electromagnetic resonator similar to a coil/capacitor tank circuit, and if the resonant frequency of the "atom/circuit" is the same as the frequency of the incoming light, then the atom will absorb a tiny portion of an incoming light wave and store it as a region of oscillating local EM fields surrounding the atom. Oddly, these fields strongly interact with the incoming light because they are naturally phase-locked to it.
The mistake was made when Einstein was unable to reconcile action at a distance. Rather than come up with a real theory that works he made the measures of space and time variable. Einstein cheated, he fudged the math making constants variable. Everyone is wrong about GR because the guy who invented it, Einstein, said it was wrong. Now GR is little more than a cult like the far right or flat Earther's.
Maxwell also cheated if anyone actually bothered to read his original work as I have. Maxwell claimed all external effects and field gradients outside the context of field lines will be ignored. He also claimed to have discarded all anomalies such as Weber's work. Like Einstein Maxwell cheated and discarded all effects which didn't align with his generalized theories which are obviously biased.
As Beaty implied, atoms could produce resonant effects in a similar way to Cassimir plates. This also relates to matter at high velocity changing it's frequency of oscillation leading to the fallacy that time changed when in fact matter did. Think about it, we take two plates in close proximity and they confine/restrict the EM waves between them. The "plates" are simply a large group of atoms thus it seems reasonable that the scale could be reduced further even down to the atomic level.
It's really strange because what most people seem to believe is not only false but a comedy of errors and fallacies from the past. In fact, what Beaty is suggesting is similar to what Maxwell proposed in his work if anyone bothered to read it. Maxwell's demon is a good start. Not the watered down and generally false internet version I mean the original literature in there own words.
If you want to learn how FE works go back and read the works of Faraday, Ampere, Weber, Lord Kelvin and Maxwell. These men knew what they were doing and did real experiments which hold a treasure of knowledge.
AC
