Motor Generator Without external Supply need. ( TEST VIDEO )
Started by JackJohn, January 09, 2022, 02:42:27 AM
JackJohn
Quote from: Floor on January 09, 2022, 12:02:57 PM
Peace be with you as well.
Welcome to the Over Unity forum.
Unfortunately I am only an English speaker.
Thank you for your presentation.  I wish you success.
Thank you very much for your welcome and pray, may success always be with you. In the video I use a different language and the subtitles also can't be interpreted 100% correctly, maybe in the next video I will try to speak English to make it clearer
Floor
Some times the best way to proceed is in a written form.
Subtitles in the video, perhaps in English.
          or
Written explanations can be printed out and then videoed during the video.
          however...
Texts which are written in a video cannot be easily copied and then
posted to an online translator.
Best are written explanations    posted online,   that accompany pictures, or the videos.
If you prefer them to be in English, you can write them in your own language
and translate them online, then post them here.
Any one can then use an online translation software and read it in their
own language, what ever their own language is.
JackJohn
Quote from: Floor on January 10, 2022, 01:57:05 AM
          or
          however...
Thank you for your good advice sir, I am not an experienced YouTuber and don't really understand how to interact with people from other countries, what you suggest is very useful
pauldude000
Jack, I wish you luck on your device, but going for amperage will be where the extra coils start producing fields of their own, which will bog down the system as those fields will be opposite of the field activating them. Lenz's law is a pain. If you want to see it in action, drop a powerful neodymium or other rare earth magnet into a highly conductive aluminum, copper, or brass pipe. The principle the law represents is what makes the magnet travel slowly down the pipe, resisting gravity.
To bypass Lenz's law requires voltage with little amperage, not vice/versa. That doesn't matter because generated voltage can be reduced afterwards to increase available amperage -- and watts = watts. If I have to generate electricity, I know that it will be much more efficient to generate 1kw with high voltage than with low, as amperage/winds determines magnetic field generated by the stator coils. Pure voltage yields weird results (voltage leading amperage by 90 degrees or more).
The biggest problem I have found is that we generate electricity using brute force. Instead of making the electricity want to flow down a perfectly good conductor it already likes to travel down, we hit it sideways to force it through the conductor at 90 degrees from the point of impact. (magnetic lines of force cutting through the conductor to displace electrons)
Treat it like a mini particle accelerator and you bypass Lenz's law entirely, as it no longer applies. Something to think about.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
JackJohn
Quote from: pauldude000 on January 10, 2022, 09:35:25 AM
Paul Andrulis
About high voltage and very low amperage, I have applied it to my device, didn't I also say above that in this test the supply of the 12VDC driving motor was able to produce a voltage of 28VAC which if DCed it would be 37VDC for each coil, while later there would be 4 generator coils installed on the those devices. That's one technique I mentioned, high Voltage low Amperage generator coil, while there are still 2 new techniques that I will include in the device whose function will be the same as reducing braking that occurs due to the Lenz Effect. I have calculated everything. Thank you for your support
In the other my test Video I've been Test about Lenz Effect on the Device with short generator coil and nothing Brake happen on rotor, I mean the speed is still and not reduce
