This one is intresting.
Started by Cherryman, January 19, 2022, 08:54:02 AM
Thaelin
Hey Ufo
   It will be the key to opening the flood gates to an open system. If it can run a grinder, then it can be used to run in an outside enclosure with lots of batts and inverters. Run it constant for a given set of bats and inverter pair. Wire the house with separate circuits and have as many units to keep the system charged.
   One 250 watt solar can charge a lot of bats with ample sun.
thay
knovos
I was distracted by the Luling machine when I saw these devices. I tried something with magnets and different alternators. If we look at the windmill guys who also convert car alternators into generators, you need extremely strong neodymium magnets to start with. Once you have mounted it, there is an enormous resistance due to the metal laminations in the stator. So a lot of power is already needed to turn the generator. The amount of power that is ultimately produced is much lower than the thousands of kilowatts that are claimed. We also don't see really heavy devices connected. Some are capable of using extremely smart video trucks. But when I see very poor people making these machines I can't imagine how they are able to fake it. There are also machines that have a flywheel, that makes everything different. Anyway, a lot of time is wasted on a machine that in the end is not 100% sure that it works. There are no plans and questions are not answered. They harvest extremely many views and get some money for it. More confidence in the Luling machine, no scam there for sure.
skybiker63
Sadly it seems to be another Scam, only wondering why some similar constructions are working.
The Video should be 100% fake, at one position on the plexiglas cube you can see the shadow of a power wire going into the wooden board.
Also they do not go fully arround the device by filming it in running modus.
When he hold it in his hands he hides the wire going under his clothes in the left arm. they put cartons boards all over the floor to hide the wire going up to his left leg.
On the left side you even could see the inverter powered by the wallsocket
They had really a lot of action to hide everything...;-)...so they do not create free energy...but they create free money by advertising...
Dusty
Question for skybiker63,
In the video when he is walking around with the unit, at exactly the 16:15 time frame, what is that black wire just above his left wrist?
It happens very quickly so you might have to slow the video down to see it.
Thanks, Dusty
skybiker63
Yes excactly Dusty, this is the wire I also saw, even on your picture you can see the cartons on the floor to hide the wir. You even can see the line of wire under his clothes.
The same wire you can see when it is standing on the clear plastic cube...comming from backside. Now we aproved that this is another scam.
The first points which made me sceptic was their crazy talk about a patent by an oil company...next was that the device did not react to any power consuption as the drilling machine.
They allready used the backside wire trick in another video...this is really high quality scam
