Free Energy Super Pack! 5 in 1!
Started by dxer_87, January 22, 2022, 01:07:54 AM
dxer_87
and the negative return is sth like this:
i hope you've downloaded the little pack!
dxer_87
Hello!
Paulos is a kind of a system to break the Kirchhoff law in AC branches. It comes from America many many days ago, in the times of medieval. It was mostly done as a separate device at the time. But old engineer think this can be more popular and used, so they tried to build something like "AC power gain" which they call amplifier when the first amplifying lamps come to the living daylight. Then this audio began... but many things may be changed in standard solution to work as paulos.
yes, heater means a heat sink. in Poland we use a word "radiator". A heater in Poland would mean an oven or sth to raise the temp. Sadly what I mentioned there is to collect the heat :), not to produce.
In my schematics I point Neutral as a Mass. The Ground is PE. In both ways. The grounding from the socket and the independent one with rod.
Mass of course in free energy can be a different thing like a piece of metal sheet or a case understood as a source. Having such source even without seen voltage and grounding you can suck it somehow and amplify to normal voltages. The system is called Barbarella or PZ00, but sadly I don't remember everything. I'll try to describe ASAP.
I don't claim anything... Just instructions. schematics, infos... You can do sth if You like. Most of them may work, but the main problem are the changes around, so that they are the keys to get it to work. I am trying to sign what is important and then I may change the parametres of those applications. It's just electronics You know. You always have input and output... probably nothing more. Some of the ideas may seem crazy, but I ve tried them as working "in some conditions".
You may try them aswell. Hope You enjoy and have a good fun with your parts :-)
activ25
You design the circuits yourself ? have you tested them ?
forest
Lepiej skup się na jednym schemacie i możliwie najprostszym i wytłumacz dlaczego wg ciebie ma to szansę działać i dawać zwyżkę energii. Widziałem podobny motyw w jednym z filmików - gość nawinął chyba 370 zwojów drutem 0,4mm na rdzeniu kubkowym (indukcyjność po złożeniu rdzenia ok 2H)  i na to dał 3-4 zwoje 1.5mm2 przewodu podłączonego do sieci AC 230V . Potem kluczował za pomocą generatora i wzmacniacza czy też sterownika impulsy na cewkę z 370 zwojami i podobno otrzymał znaczny spadek poboru prądu z sieci.
Floor
@ dxer_87
Your schematics are well drawn, thanks.
The circuits look like they might have been well thought out as well.
Hopefully they will be as you say,   fun  and  educational.
     cool
         best wishes.
