Permanent magnet assisted motor coil designs
Started by captainpecan, January 24, 2022, 02:35:06 AM
gyulasun
There is a short manual here, have you read it? under Product guides and documents  https://m.media-amazon.com/images/I/B1E36nhld0S.pdf
down towards the bottom of this page   https://www.amazon.com/Converter-DROK-12V-120V-Adjustable-Regulator/dp/B098SVD2B8/ref=sr_1_15
captainpecan
Yeah, that came with it. I have it all set but it is still a little wierd on the current draw. Its not like it isnt working, just not like a straight power supply would. I missed something in the settings I'm sure. I've been out of town for work since I first tried. I'll look it back over again when I get home.
jimbo
Captain pecan
This might be a little off topic .well I don't know how to help you but I was considering using different size caps to find the right voltage / joule for a clean pulse release .the power source would be secondary just charging the cap and it being ready to fire on command .if you were to set the power source to the needed voltage / amps then run that to a cap of the right size the quirky ness of the power source might be midigated.
jimbo
I really hate to say this but I've found aother path to over unity and has greater potential for energy and less trouble and more immediate power and less time to build and off the self parts .it comes in two sections and both inhance each other . first is a variant on the Flynn motor its a reciprocal motion going to a circular motion a wheel just like the old steam engines 😱. That uses a old large transformer cut down and unwound then rewound .then the side steel lamanets go in and out as the magnets switch so you get power each way .it gives you the 1 to 4 power return as rotation .the the second half is a standard generator wheel with neos like 6 neos or more the difference here is slightly smaller neos on the rim that are in repulsion mode the match the power neos on the wheel .this is called magnet neutralization and it seems neos are good for this as they last a long time under these condition not easy to demagnetized . the numbers are amazing and not small power either. Start with say 100 watts into the Flynn then 400 watts of rotational  power out then that going into the modified generator .the generator get a 2/3ds increase in power when running in the video he says it takes 400 watts in to run it and he gets 1,044 out !! So starting with a 100 watts your putting out 1,000 watts !.each has merits but together 1 to 10 ??. And not to hard to make .this could make a huge difference in my life .air-conditioning cooking lighting full batteries with out the sun . and mostly off the shelf .please forgive me I'm weak .😂
lechancel
