rakarskiy
Quote from: kolbacict on July 31, 2022, 12:54:10 AM
Well, at first I supposed that this energy is taken from the virtual rotation of the field.
Because in a mechanical electric generator it is necessary to expend mechanical energy
to rotate the rotor. And here it goes, as if for free. There were even myself thoughts on
how to improve this process. But you ignored it. But now you are claiming that the excess
energy comes from amplification in the steel... All known transformers are made of steel.
But there is no OU in them.
How does a TRANSFORMER work?
The second question is how does the GENERATOR work?
Why is the voltage regulation at the input of the transformer produced by the control of the voltage at the input to the primary winding?
How is the voltage regulation for the circuit, where the source is the phase of the generator with a field source from permanent magnets?
Solve a simple problem:
Determine the EMF of the generator phase to which a load of 1 kW is connected, while the voltage at the generator terminals is 220 volts.
kolbacict
QuoteHow is the voltage regulation for the circuit, where the source is the phase of the generator with a field source from permanent magnets?
In ordinary   nohow. Only by changing the number of revolutions per minute.
But now they've probably come up with something to do it differently.
p.s. But none of you knows how a wind turbine generator works. :-[
But I know.  8)  I was explained on the forum valvol.   8)
How is it that at different shaft revolutions it has the same frequency at the output.This generator does not have a rotor with permanent magnets, but has a three-phase winding, similar to that on my selsin. Which is powered by an inverter with a variable frequency.  But this is offtopic.
rakarskiy
Quote from: kolbacict on July 31, 2022, 02:50:44 AM
Then the generation frequency will change, let's say we need a name of 50 Hz.
PS
Quotep.s. But none of you knows how a wind turbine generator works. :-[
Volodin is a very competent electrical engineer, but he can see that he cannot do such a simple task as a transgenerator. The standards of circuit solutions are to blame for everything.
I also did not understand everything right away, for this I needed wild altruism on a rake.
kolbacict
Quote from: rakarskiy on July 31, 2022, 03:25:44 AM
Quite right. I just don't know this device. I don't know yet... ;)
rakarskiy
Here is a video of a Blogger from Kharkov (Ukraine), a good video about a rotating field, if it helps you
https://www.youtube.com/watch?v=HSSIV-H58e4&t=3s
