bistander
rakarskiy
First, put the traditional values ​​on the frame of the generator, in the magnetic flux, in the position that I have in the figure. Then you can compare something.
bistander
Quote from: rakarskiy on December 19, 2022, 04:01:13 PM
Okay, you lost me. Can you provide a reference, in English, from an accredited source? Showing the E field from a current carrying conductor circulating around it?
bi
edit:
A current isn't required for the motion induced voltage in the conductor moving in the field. So the induced voltage or potential difference is perpendicular to the motion, along the wire length. But I do not believe E can circulate like you show. Electric fields are divergent.
2nd edit:
There is no motion in Holcomb's device, so isn't this off-topic?
rakarskiy
As for the ruhu emf vector around the conductor, there is no time. This is the continuation and essence of a separate work.
As for the Holcomb generator, it has the physical movement of a magnetic field, analogous to the movement in a mechanical generator. This is what distinguishes a generator from a transformer.
I won't go into details as research is still ongoing. I'm not designing a Holcomb machine, I'm doing an impulse system. It is more difficult for me to reach full hysteresis.
SolarLab
Quote from: bistander on December 19, 2022, 04:12:15 PM
bi
edit:
2nd edit:
Hi Bistander,
By studying the patents and related presented material in detail, and inter-relating the [maybe initially complex] technical information,
you will quickly find the relationships - there are many; but one by one they emerge. Take it step by step and the concept will surface.
It's not that difficult, really. Each component will become clear.
There are only four components to the system overall as outlined in the OUR thread. Not trying to be a twat but that's what's required.
Review the material and it will quickly become evident.
If it doesn't suite your current concepts or beliefs then try viewing it from another angle or move onto something more suitable.
SL
