SolarLab
Quote from: rakarskiy on January 09, 2023, 12:48:08 PM
I do not want to reassure anyone, but nothing will go to the market, at least until the system allows it.
As for Holcomb systems, is 200 kW a household system? You think that its maintenance or content is such a free budget item.
Another aspect is integration into the power system, and these are approvals and permits, etc.
Holcomb generators are planned as power amplifiers.
In my research, this is another episode where everything is flushed down the toilet. The system can roll out any project.
Unfortunately!
Well, we may not see one at the Big Box store any time soon, or ever!
But, since those skilled-in-the-art can actually build them (with minimal effort and resource),
and, since the size can be quite small; just add a "plug" to the box and run what ever this
independant power source is capable of (sort of like a solar cell when your camping, or at the
cottage, or on your boat - and you don't need a battery when the Sun goes away). Lots of
configurations and variations - DC, AC, both, lots of voltage and current combinations, etc..
Handy after an ice-storm or hurricane or whatever as well. Put it in your Tesla or electric bike.
Of course, if you wait for someone else to do it first (as some here spout) then - oh well!
For me - it's a wonderfully educational and exciting hobby...  a lot of fun actually and quite
practical. So, quit wining and start winding!   :)   Plus, you get to learn programming!  :(
bistander
Quote from: SolarLab on January 09, 2023, 12:29:09 PM
Pix,
The B-H characteristics are a lot more complex than just one small aspect known as "hysteresis."
There is no "trap," but instead, it's a method to achieve a "gain" - for free almost!
Professional CAE Analysis (all three major ones) clearly show the results are not what you claim. In
fact a complete set of CAE Analysis has been presented over a series of posts on an OUR Holcomb
thread. Some of the first analysis examined differing materials and the results are clear.
All commercial generators "are" free energy but they have to configured correctly - this is exactly
what Dr. Holcomb has done and he is now in the process of bringing these to market. But it does
take some time, as we all can appreciate.
If you look carefully in more detail you will eventually understand how this technological approach
works. Forget the engrained orthadoxy, this will help a great deal. Review the work that I have
presented at OUR in great detail, it will also help a lot I believe.
Regards,
SL
Hi SL,
you say
QuoteAll commercial generators "are" free energy but they have to configured correctly
and you have said it can be replicated. So what is the correct configuration? Let's be specific. Using a model 283CSL1506 from https://www.marathongenerators.com/generators/images/SB0073E-60Hz.pdf intended for 25kW, what is this correct configuration to obtain free energy?
I have used Marathon motors and generators in the past, and been to one of their factories multiple times and worked with their design/application engineering departments years ago. I suspect my contacts are retired, but I am sure I could purchase the model mentioned or suitable equivalent, and would be able and willing provided I was supplied this correct configuration.
bi
SolarLab
Quote from: bistander on January 09, 2023, 01:23:12 PM
Hi SL,
you sayand you have said it can be replicated. So what is the correct configuration? Let's be specific. Using a model 283CSL1506 from https://www.marathongenerators.com/generators/images/SB0073E-60Hz.pdf intended for 25kW, what is this correct configuration to obtain free energy?
bi
There are a multitude of configurations, choose what ever one suits your needs and capabilities.
Holcomb provides some hints in his many detailed patents but it sounds like your quite experienced
at this sort of thing. Me, I'm not - maybe someone else can give you a "paint by number" scheme.
My target is the "LinGen" device since, for me anyway, it's easier to fabricate and there's a wide choice
of ideal electrical (soft/pure iron, etc.) steel available to experiment with. But off-the-shelf motor steel
should work ok - as demonstrated in the HES (maybe only 2X or 3X - but good enough).
That's where the "one-skilled-in-art" part comes in! Probably worth the effort when considering all
the applications.
Good Luck
Ufopolitics
Hi SL,
bi
Hello Bi,
You will need to get images of the interior (rotor core) and since it is based on a 4 pole 3ph gen, then you could go with a Rotor Armature Core which fits inside the Stator diameter (could be pretty tight, since it is not going to rotate)
More likely you will need to have laminations cut for you in a waterjet or a laser jet cutter machine shop...
Or, if you get lucky, you could find a 3 Ph Motor Rotor, which has same length and diameter as generator...saving some time and money...however, it must have at least 72 tooth to wind all your coils...
Note: If you need a CAD drawing of the laminations to be cut, I could do that for you at no cost, given the spec's (like steel gauge of laminations, length, diameter).
Then you will need to calculate the wire gauge and # of turns required to produce same Field strength (per pole) as the normal Generator Rotor does, based on its own self exciting system of coils on the stator...I imagine it would be a brushless type 3 ph generator.
But I am sure, you would not have any problems on your calculations, since you are an expert on these fields.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
kolbacict
Quote from: rakarskiy on January 09, 2023, 11:26:00 AM
The generator has a constant field, the transformer has an "alternating field", and in fact it is pulsating.
I have a pump "johnson pump"
in which the torque from the motor to the impeller is transmitted through a magnetic coupling.
This is done to completely isolate the motor from the pumped aggressive liquid.
In this magnetic coupling, a constant field or an alternating one rotates?
