ariovaldo
The conception is different, but one common thing is the excitation or DC coil / electromagnetic.
http://jnaudin.free.fr/html/mmcgen.htm
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
bistander
Quote from: Ufopolitics on January 11, 2023, 11:42:18 AM
The simple ones, the brushed type...because since we do not have any rotating parts, it would just be wires running from stator coils to exciter coils.
Do you understand what we all need here?
Thanks again
Ufopolitics
No rotating parts, you say. Then you need a power supply. Just connect it to your field coils.
There are no exciter coils, so no wire gauge, turns, resistance, inductance, etc. Just use the power supply to properly excite the field.
bi
Ufopolitics
Hello,
Point is that if we completely remove the Output Coils of a Generator...and rotate its exciter rotor, the Energy would be produced at its Stator Feedback Coils and sent back to keep rotor energized...and that is the point, all we need to do is spin the Magnetic Field...without ANY EXTERNAL Input directly to the Exciter System...
For example, in my setup, I can rotate the Magnetic Field with just 12 Volts and some milliamps to the small motor Rotary Switch system...while this rotation will trigger the excitement system to start generating on the exciter coils back and forth exchange for up to 170 Volts and 2.0 Amps...
It is simple...it could be done Guys!!
I am working on having also a belt of magnets which will "act" as the PMG on a 3 Phase Generator exciter armature...except, it will be rotated just by the 3 phase system from its exciter coils...then inducing the output coils.
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: bistander on January 11, 2023, 12:15:40 PM
bi
But I do have a "rotating part"!!...only that it is virtual...no mass... ;)
And that is what we do NOT need, an External Power Supply to excite the Inducing Fields!!
By just spinning the Field, we should be able to generate bigger power and store it on Caps, which would be constantly replenished, keeping exciter rotor ON at all times.
Only external supply required would be to the rotating circuit, whether a small motor, or the solid state system, both easy to be fed back from main output..."nickel and dimes"...
Ufopolitics
―Leonardo da Vinci
