rakarskiy
I hope this material of mine, will help to understand how the traditional synchronous oscillator and Holcomb generator works.
GENERATOR AS A SOURCE OF ELECTRICITY
tinman
Quote from: rakarskiy on September 01, 2023, 05:50:54 AM
To quote your paper--(What is the peculiarity of an electrical circuit with a galvanic element? As stated earlier, the galvanic cell does not have a complete conductor closing into the circuit. If we consider the design, then between the plates - electrodes with electrolyte, no current is generated, no matter how orthodox physicists would like it. A short circuit between the electrodes, disabling it, and in some cases the occurrence of an electrochemical reaction with the release of a huge amount of heat, is the same as if you short circuit the electrodes of an active (charged) galvanic cell. The current strength—the magnetic vortex field—does not pass through the electrolyte. Thus, a galvanic source cannot be a source of current or a generator of current. When they call electric current, uh,)
Totally incorrect.
Current does flow between the plates, as it does between the plates of a capacitor.
The conductor between the two plates of a galvanic cell is the electrolyte. This can be proven by the fact that a magnetic field is produced between the plates within the electrolyte. Remove the electrolyte, and you are removing the conductor, and no current will flow.
rakarskiy
Quote from: tinman on September 01, 2023, 06:36:22 AM
Totally incorrect.
The same through the capacitor (called "like" phase shift of the current), but there is one BUT, the spin of the magnetic field in the capacitor, as well as in the electrolyte "under question as it is only theory" has the opposite spin to the spin in the electric circuit to which the source is connected. That is, the current vectors are opposite, which excludes short-circuit in the circuit.
a significant contradiction of accepted tenets, don't you think?
kolbacict
QuoteThere are two types of generators - a voltage generator and a current generator. This is a fundamental thing indeed, pay attention! See pictures below
Well are there toggles of current and toggles voltage ?  ;)
adrouk
Quote from: SolarLab on August 30, 2023, 07:03:08 PM
Hey Fellows,
You've probably already reviewed all the technical and other information I've provided so far, mostly on the LinGen, but
also on the HES technology in general.
So, what else do you need, if you really do need anything more, to understand the theory, methods and techniques; and,
hopefully be able to construct a device or have a typical model/fab shop make one for you.
You already have been given the links many times so I won't repeat them again.
BTW, check if the patent showing the "so called" LinGen was ever granted - it claims perpetual motion (OU) so it probably
never received a granting. Even if it was granted, you can still build a few for personal use/experimentation under the law;
you just can't sell them to the public for profit.
Not sure what the reprecussions would be if you built them and just gave them away however - like an "open source" thing!
Still can not figure out why you guys fight this "Holcomb Technology" and "Excess Energy" thing so ruthlessly. Take the "tech"
and run with it, in what ever direction your research takes you!
Have a good one... and take care,
SL
I'm not fighting against FE or OU, but you cannot harass ou community nor Holocomb. If Holocomb has choose their way to patent this tech and already pursuing production line for their product, why are you trying to make their life more difficult ?
If they need help and asking for replications while keeping their path to patent isn't going anywhere when some disclosures are made in an open forum. I just don't want to conclude about the logic of action or speculate about reasons behind scene.
I really think Holocomb deserve a rest from all this nonsense. Or Holocomb needs to come in the open with a fair trade if they need help ... the only risk as always, is once in the open, the only real fight is on production force as I can see happening soon enough with Holocomb or any other. Is just marketing strategy and they can choose a cheap franchise release to get some financial gain rather than expose the tech even under patent and make no income ... I don't think that nowadays is anymore possible to see things happening as some 20-50 years ago ... just look how mobile communication evolved.
We already have a lot of things that only need scale up as they are proved to use FE and/or OU in a novel way/approach where we can apply some of the newest tech available even for diy.
