Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
Ufopolitics
Quote from: citfta on July 06, 2022, 12:05:05 PM
Hi UFO,
That part I highlighted is not completely correct.  In a regular generator the speed determines the output voltage.  And the torque requirement increases as we increase the load drawing more current as you correctly stated.  The speed is controlled by the governor of the engine if an engine is used to power the generator.  If the speed changed the AC frequency would also change which would not be good for most appliances with induction motors.  But the governor maintains a fixed speed unless the generator is severely overloaded.
What is very interesting in your design is that even when you maintain the same speed of rotation of your field the voltage DOES change when the load is applied.  That may be because your generator is not capable of supplying the current needed by the load.  I believe if you load your generator with a smaller load more matched to your generator you would see it respond like a normal generator EXCEPT adding the load will not affect the motor driving the rotating field.  And THAT makes your design very interesting.
Respectfully,
Carroll
Thanks Citfta,
Yes, you are correct, I was  "throwing" all together there, on that statement...actually, torque and speed are tightly bound on a rotary generator...meaning, if torque requirement increases by generator demand to ICE, it also means a speed drop, until ICE reacts through governor...and rises speed and torque.
Actually Torque is inherent to any ICE whenever it spins.
Related to my V drop, you are entirely correct, is only due to currents not satisfying the load demand.
And I know where error is...I wound too many turns on my stator, plus I used 20 ga...which throw resistance too high for a generator stator.
I got much better results whenever I parallel stators, but V is not as high...so everything is a matter of tight and precise calculations of all together for a successfull machine.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
kolbacict
Quote from: Ufopolitics on July 06, 2022, 11:16:10 AM
However, on the stationary rotor, we just need to speed up field, in order to compensate Amps Input (down) and Amps Output (up)...no torque required here...my small little motor can handle ANY size Magnetic Field Rotation...isn't that great?
Everything is clear with the electromechanical switch. And the current consumed from the DC source does not increase?
If not, then that's really great.   :)
Ufopolitics
Quote from: kolbacict on July 06, 2022, 02:41:43 PM
As you increase Field speed, Source Current drops, lower down, Output Current rises...simple Math Guys.
All you have to make sure is not to lower too much, otherwise Field will loose strenght.
That's it folks... ;D
―Leonardo da Vinci
Feb2006
A simple HES Lingen with only two input coils, a north and south coil.
And charge a capacitor with the stator coil to even out the spikes.
Solarlab, what do you think would this work ?
seychelles
one of the secret of this device is that THE OUT PUT CORE IS BEING MODULATED FROM BOTH ENDS.
I WOULD ASSUME THAT GENERATE A MAGNETIC TORNADO WITHIN THE INNER CORE.
