Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
Feb2006
That's why  I'm not sure the simple two pole LinGen will work.
In The LinGen there are  some colis  on and som coils off at the same time
and that's making the magnet field  always on.
So maybe you can put a bias on the input coils or two bias coils
on the simple two pole LinGen.
But maybe you need that, maybe not.
In the latest patent application its still LinGens that is rotated (not mechanically)
at various speeds to generate 60hz, 50hz  or other hz AC output.
kolbacict
Therefore, you beleive that there is a fundamental difference between a rotating permanent magnet rotor and switching windings.
Even if the number of these poles tends to infinity, and the dimensions of a single pole tend to zero?
ariovaldo
One point that called my attention.
In his "Charlie Brown " prototype, there is a gap, cutting the stator.
Also, there is a mix of thicker and thin magnet wires.
It is just food for our thoughts.
Ariovaldo
ariovaldo
My trial.
I"m using an old generator stator.
This didn't work as I planned.
The slots are too small
I still need to re-wound the rotor.
rakarskiy
