Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
Ufopolitics
Quote from: bistander on January 14, 2023, 01:14:15 PM
Ufo,
The Exciter Stator Coils are its Field, not its Armature.
bi
Hello Bistander,
Yes, I missed to  write down in that sentence "according to image shown".
If you notice at the image, where it shows "main generator" in a green square done by me, the two outer rectangles with windings loops are named "armature" as in the center (supposed to be the rotor, is called "field" (unless it is an Outrunner, which I doubt very much)
What I was trying to convey, is that if you notice there are 3 wires running from GCU (Generator Control Unit) to the so called "armatures" on the outer side...so I am  assuming there are also Exciter Coils there as well.
GCU do not need to run wires to Generator main frame stators, unless it is going to exciting fields.
By sending the DC Power to Rotor via the rotating rectifier is enough for generator to work fine.
Anyways, I guess it is a wrong writing at that image...that btw, it was you who posted it on Citfta's Thread yesterday.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
@SolarLab,
Hello friend,
I have commented way back about this explanation from HES...IMHO, it is not fully correct.
First, typical generators (ever since they were invented) do not align the steel domains "only at startup" but at all times during their operation.
Every half rotor turn (for a two pole and every 45º for four poles), or whenever they reverse their polarity (N-S) by changing rotational positioning related to stators, they are reversing all magnetic domains at steel cores on stator.
Now, the claim "Eliminating Reverse Torque" is an obvious one, since HES Generator claims after "not having any moving parts"...and torque is always a component of any existing rotational or linear displacement movement.
Resuming, even though steel does enhances and strengthtens magnetic fields, IMHO, it is not the direct and real main cause to justify the "excess power over input".
The real reason for any type of machines configuration like HES to be overunity, relies on the simple fact to spin or displace the magnetic field "virtually", not physically, meaning not involving any rotary steel and copper mass, hence, not depending on the Internal Combustion Engines any more, to rotate the weightless, massless magnetic field.
But more likely, I am very sure at HES they know all that very well, and simply because the "Saint Inquisition Laws" at the Patent Office, where it is a "Felony of Third Degree" to even mention that the ICE would be totally eliminated, and no longer required of their "services"...would be a very solid justification to deny the granting of any Patent in the USA.
Even though, the granting of all HES Patents includes a classification labeled within the "Alleged Perpetua Mobilia Status" tag.
Ufopolitics
―Leonardo da Vinci
bistander
Quote from: Ufopolitics on January 14, 2023, 01:53:26 PM
Hello Bistander,
Cheers
Ufopolitics
Ufo,
Notice that the 3 wires running from the main generator armature (its stator) are dashed, indicating they are feedback to the GCU to enable voltage regulation by adjustment of the rectifier taking 3ph AC from the subexcitor armature (its stator) which delivers DC to the exciter field (its stator).
bi
Ref: https://www.mdpi.com/1996-1073/13/11/2696
rakarskiy
Hi all!
It was not by chance that I said that mechanical and HES work according to the same algorithm. The iron of the magnetic circuit of both generators is in maximum saturation, which can be attributed as a post-stripped magnet. How control through provocation works, since the constant field lives by constant replenishment.
The working field of the generator is created mainly due to phase currents.
Holcomb is absolutely right, the firing of the excitation and the operation of the excitation are probably different. I am not doing this yet, at the moment I am fully occupied with a transgenerator combination, where the field is controlled through electromagnets. But in any case, the main field should be from the phase current, this is the difficulty.
Now I understand the expression "construction of an electric generator, aerobatics of electrical machine design"
Sincerely.
Feb2006
Quote from: Ufopolitics on January 14, 2023, 02:18:19 PM
It also depends on how fast you spin or displace the magnetic field "virtually".
If you do it faster than 250 times per second you get more out but it depends on the
Material if you can do it. It's like the faster you move a magnet back and forth a wire the more you get.
My ferrite core can do 100000 Hz.
