Just another Don Smith thread
Started by nix85, April 11, 2022, 10:54:51 AM
Vortex 22
Because I have done that many times
It's make sense to me that If I am using high voltage like 10 kV or high frequency like 30 kHz
The speed process of charging the Cap will go faster
But only experiment can tell the result !!!
Vortex 22
Because I really don't like to play with higher voltage?
Maybe
The coil can harvest too?
Not any coils can
Will setup a pancake coil under certain conditions to see th result?
pix
Quote from: nix85 on May 11, 2022, 12:21:43 PM
Regarding the pumping electrons from ground, he used a small tesla coil
to excite the cap plate, keep in mind tesla secondary is usually coupled
to ground through the air capacitively, thus closing the circuit.
Only way that demonstration would be truly as claimed is if tesla coil is not
grounded/earthed, like the small, battery powered chinese boosters.
The "million" volt ones produce up to 180kV (measured).
In short, it uses a single transistor oscillator
which powers a transformer converting 3-9V into 1500V
which charges a cap and when it charges to 1500V it fires
through a sparkgap into a small tesla coil amplifying it further
to 180kV or maybe even little more depending on the unit.
These units are complete, utter junk, they usually break down
within minutes, if it lasts few days it is a miracle.
Don't interpret this as debunking, i already shared a great video
of 1100W load being powered by 9W between a resonant transformer
and earth. So this effect has been confirmed many times.
It's just delicate and most fail.
Yea, the host in that Don's video claimed they run the small tesla coil
from a battery and made sure circuit cannot be closed, but we
have to take his word for that.
Tried this. No OU there.
Charging one side of HV capacitors with High Voltage AC  , connecting other side of capacitors to the ground through HV diodes.
I called it "Earth electrons pump".
It takes energy from the source to induce opposite charge on the other side of capacitor.
Cheers,
Pix
Vortex 22
If we find that coil electron captor really exist?
Then Will combine it with the capacitor electron captor?? Maybe this is Don Smith resonance talking about? Who knows
nix85
Quote from: pix on May 11, 2022, 01:10:38 PM
Cheers,
Pix
Take a good look at what happens, he is powering 1100W of bulbs between Earth (radiator) and resonant transformer with 8-9W input.
https://www.youtube.com/watch?v=Y3dc-5tPc90
