Just another Don Smith thread
Started by nix85, April 11, 2022, 10:54:51 AM
ramset
Sir
Regardless OP's lack of request, there are untold numbers of persons
who spent endless hours  banging head against DS info wall ...
Zilano probably pushed a few more sensitive souls over the edge ( sanity)
Quite certain MANY would appreciate to know where they went wrong ...
I had noticed you mentioned old Friend David F
Have not spoken to him in ages
Sure he would also be interested...
Respectfully
Chet K
Ps
Perhaps bump an old thread here!
Thanks Grandma
nix85
Quote from: whitelightningwizard on May 04, 2022, 09:18:55 PM
@nix85
well he explains in 2019 video that he can light a bulb and produce multiplied magnetic field from the current he is using. so its like winding up current b4 using it which is more than what the supply gives u...
it's Russell way of using grid AC power. Power Multiplication.
So he claims it, no demonstration. No measuring of input output. Not much of replication.
OP did not ask for help building Don circuit?, then my mistake. I'm in wrong place.  :-
Did not ask for help, ever. I asked if anyone had success and that was not really asking, i expected no one will, as my OU playlist shows, i know of many successes.
Russell is 1 perspective, but he had whole Universe in his gaze. He actually knew secrets of the universe. IMHO.
Tesla dying of old age said he still didn't know what electricity is.
Yes he did, but so did Keely long before him, so did Theosophical seers with their astral sight, who could see inside the subatomic structure, who understood the governing principles of polarity, counterspiraling motion, compression and expansion, all this long before Russell.
Quoteyup Don knew radio pumps out 1 signal and can have multiple harvests if we tune receivers.
maybe I have opened eyes for some on here. idk.
You opened no eyes cause your own eyes ain't open (enough), i am trying to help you open your eyes but you are transfixed on your religion.
Take 10min, read my last two posts slowly, learn about creation of time-space Carrier Field from nothing using interference along 6 AXIS OF TIME, and subsequent creation of bubbles (MATERIA PRIMA) by "digging holes in space" which in turn create all lower orders of matter by their counterspiraling motion....
nix85
Keely was right cause he was right (and time will show that), the fact that he preceded Russell is another thing.
No, i do not think "that's not true", i said many times opposing spirals are the principle of Creation, i critiqued his lack of measurement. Here is an example of a proper demonstration, 1 in 122 out.
https://www.youtube.com/watch?v=Y3dc-5tPc90
The point of studying Keely is not getting OU, it is for better understanding of mechanisms of Nature, universal triune force flow, laws of harmonic and discordant vibrations etc.
You of course did not read the Cosmic Time Field Carrier model on the last page, my my, if you only knew you are ignoring the very mechanism of Creation of Time-Space and everything in it.
As for that steam turbine of Russell, i'm gonna quote from a letter Schauberger sent to Mr 'R' From Implosion Magazine, No. 82, written in Linz, 4th February 1958.
Thirty eight years ago as I was building the first log-flume and mixed and moved the water in such manner as to trigger a falling thermal gradient, I had no inkling that this was the initial stage in the build-up of a concentrating form of atomic energy. Acting purely intuitively I proceeded further along this course. In 1921 I built the first suction-turbine to provide and light my remote forest-homestead with electricity. With it I achieved an almost nine fold increase in output. This I deemed to be the most natural thing in the world and once again took the next further step. I utilized this falling thermal gradient for the purposes of re-converting polluted water into noble water - akin to that of high-altitude springs. This water exhibited remarkable healing properties that nobody was able to explain.
So there is your overunity water turbine in 1921.
Little more about Schauberger...
Schauberger noted that everything in nature has bipolarity: light and darkness; warm and cold; male and female; pressure and draw, etc.. Between these opposites exists a constant flow of elevating qualities running from the lower to the higher one in a logarithmically spiralling movement. There are two spiralling movements: one outward-going sucking energy away from the centrum in excentric centrifugence, and one inward-going which presses energy in a concentric centripetence towards the condensed centrum.
The core philosophy of Schauberger could be expressed as follows: The force is life, and the secret of life is bipolarity. Without opposite poles in nature, there is no attraction and repulsion, there is no movement. Without movement, there is no life.
Each movement has its characteristic qualities: The outgoing movement is followed by an increased friction and increased pressure with a rise of temperature, biological breakdown and decomposition. It is characterized by the processes of explosion, expansion and gravitation. The in-going movement is followed by a decreased friction, decreased pressure combined with decreased temperature and biological improvement. The corresponding processes are implosion, impansion and levitation.
Even when the two movements are naturally balanced as two opposing forces of equal strength, the inwards-going concentric spiral dominates in its reconstructive role.
The spiral movement may turn either counter-clockwise or clockwise. When the motion spirals counterclockwise, it has a structuring and formative influence on material flowing (fluid or gas) in the implosion spiral. If it turns the opposite way around, its function is decomposing and disintegrative. The greatest vitalization is obtained when both spirals move inside each other. Such resultant or double concentric spiral movement is called the implosion spiral and constitutes the essence of Schauberger's implosion theory.
Schauberger used this theory to explain certain natural phenomena such as typhoons, whirlpools, certain shell forms, the meandering of waters, and new forms of energy generators (including his levitating implosion disk).
Etc.
"All corpuscular action in Nature is vortex motion." [Keely]
Below are few crops from The First Principles of Theosophy By Curuppumullage Jinarajadasa first published in 1921, 5 years before The Universal One and as far as i know all this is taken from much older work of Blavatsky, Leadbeatter and Besant.
https://www.minhtrietmoi.org/Theosophy/Jinaradasa/The-First-Principles-of-Theosophy.htm
We see he clearly says that logarithmic spirals are at the heart of Creation on all scales.
We see spirals within spirals creating different orders of matter.
We see Russell's spiraling chart of elements long before he thought of it.
The next two illustrations, of a spider's web (Fig. 111), and of the Periodic Law of the chemical elements (Fig. 112), link in an undecipherable mystery a microcosm with the Macrocosm. For in the center of the spider's web is the logarithmic curve; how does the spider know to build according to geometrical principle ? And why does the universe, as it comes into being, create 92 elements in such a rhythmic fashion that we can group them into families, and tabulate them all according to their atomic weights, so as to make a spiral curve similar to the spider's and to that of Solarium (Fig. 102)?
Etc
You got "working devices", great, i will too soon but your knowledge/understanding is too limited. You don't even acknowledge the Triune Flow, the fundamental Universal principle we find in all forces and matter, or the 6 phase COSMIC TIME CARRIER FIELD that creates the 3D space itself and keeps all atoms spinning in sync....
Enjoy the silence :*
tomd
@wlw
Both Zilano and Don mention frequency can be controlled using resistors. The following is from Zilano:
T=RC AND T=L/R
T=50 HZ OR 60 HZ
SAY T=50
AND C=2mfd
T=R*C
50=2mfd*R
R=50/2mfd=50/.002f=25,000 ohms=25kohm
say L=25mili henry(mh)
and T=50 hz or 60 hz
T=L/R
50=25/R
R=25mh/50
since 1mh=1/1000 h
R=25/50,000
R=0.0005 ohms
put R for C in series with cap and R for L in parallel
the circuit will oscillate the primary of trafo at 50 hz or 60 hz accordingly.
T is the time constant for a capacitor and inductor so how does that work by substituting frequency?
I assume the cap she is talking about is a storage cap after L2. I have read where Don also used a nomograph. Does it do essentially the same as the two time constant/frequency formulas?
How do these methods of frequency control compare with making the primary of the isolation trafo part of a resonant tank circuit at 50/60 Hz?
nix85
Something more on 8 tonal division we find in Theosophical and later Russell element chart, this is Denisovian science, Denisovian were cave people of Eurasia 200,000+ years ago up to last ice age, and were supposedly a prehistoric autists (having supposed autism gene).
https://ie.ussyms425.com/2502-did-autism-make-the-denisovans-savants-of-the-prehis.html
https://youtu.be/qcnrnLptKKI?t=642
They knew about the Saros Cycle and probably based their calendars on it.
The saros is a period of exactly 223 synodic months, approximately 6585.3211 days, or 18 years, 10, 11, or 12 days, and 8 hours, that can be used to predict eclipses of the Sun and Moon.
Below is a 24,000-year-old mammoth ivory plate found at Mal'ta in southern-central Siberia showing what appears to be 7 logarithmic spirals.
And below is a calendar round displaying the proposed grand calendrical system of the Altai-Baikal region, which is at least 24,000 years old.
You can see all numbers are multiples of 9 and there are 8 'tones' per 'octave'.
Obviously this is not a musical or light or elements chart but i am drawing a parallel, that it is wholly based on 9 is surely no coincidence.
As i said before 8 tones is something between a diatonic and chromatic scale.
Below is the table with "most harmonic frequencies" containing 8 tones (not in order).
Full diatonic scale is
G, A, B, C, D, E, F#
Full chromatic scale is
A, A#/Bb, B, C, C#/Db, D, D#/Eb, E, F, F#/Gb, G, and G#/Ab
So 8 "most harmonic" tones are basically a diatonic scale with addition of C# or chromatic scale with D#/Eb, G#/Ab and A#/Bb  missing.
All tones/frequencies except for C and G are based on 9, C and G are not but they nonetheless include them.
Why? Cause it is a MULTIPLICATION TABLE. All frequencies are product of the 2 coordinates.
So these 6 which are based on 9 can be traced on the Denisovian calendar and you can see how tones progress in steps.
Take for example tone D2 which is 72Hz, look at Denisovian circle, next harmonic 144 is just one step away, yet next higher harmonic 288 is 2 more steps away.
Or take E2 which is 162Hz, on Denisovian circle next harmonic 324 is 3 steps away, yet next higher harmonic 648 is 6 more steps away. Obviously, we got a Fibonacci like progression which may be represented as a spiral.
The whole point is Theosophical/Russell 8 tonal/element division may reflect the 8 "most harmonious tones".
I'd say that this is the very essence of Triune Flow, how One splits into 3 and further subdivides into 3 more and more into infinity, fractally - i am referring to the table horizontal division determining difference between tones, vertical division is just doubling of the same ratio.
Triune flow is supposed to have ratio of 369. This ratio we find all over the table of most harmonic 8 tones as 2 octaves of one tone which are like 3:6, that is, second is double first, and third tone which is 1.5x the second one is a tone on the right of the first one.
For example 216, 432, 648. 432 is twice the 216 and 648 is 432 x 1.5.
If this geometric pattern is kept 3 tones will always be in 369 relation.
