Giant Storage Battries
Started by Thaelin, May 18, 2022, 05:32:05 PM
Cadman
You know, what intrigues me about this idea is the size of it. Lately I've been thinking about how a person could make batteries from junk yard or scrap yard materials including anodizing some steel. Drums might be hard to get but plastic 5 gallon pails are around.
A bucket, stripped wiring from junk cars and some steel and charcoal might make a pretty good battery.
Just ordered some alum the other day to convert some other batteries so this is a good time to experiment.
sm0ky2
Carbon / copper does provide a potential (if its the right form of carbon)
Graphite (and even better graphene) will do this, as per the series.
The problem is the current is generally minuscule.
It is a factor of surface area, so making it large does have a bit of sense to it.
Stephan is correct in that the set-up in the video will cap out around 0.7-1.69V
(enough to power a superbright LED spotlight)
and if there is enough current - power it brightly.
The 5-gallon bucket idea seems more economical than buying hundreds of 50-gal barrels.
Even if you didn't go all the way, a series of buckets could step the V up enough to drive a motor
or greater if you had enough of them.
The addition of an electrolyte could increase productivity, although i would initially test using
Deionized Water
However, with the use of an electrolyte keep in mind
the potential of carbon is 0
the potential of copper is -0.34
So the lower the ionization potential of the electrolyte the better
Tubing is better than a wire because of the surface area
There is not a lot of info seen in the video
That appears to be standard graphite filter rod
(Used in aquariums and industrial filters)
If you get a used one there may be unknown contaminants.
Simple testing could tell us if this warrants any further investigation.
Cadman
Thanks Smoky2,
That video is bogus, no doubt, but it got me thinking. A big battery with a filler to hold the electrolyte is what I had in mind. Anodized steel (anodized with KOH) and brass with KOH electrolyte made a good rechargeable battery
If the ordinary charcoal is not a good idea for a filler, what would be? Common soil? Sand?
Something you could find anywhere for free would be best.
