Capacitor Electrons Captor from Don Smith / Tesla
Started by Vortex 22, May 27, 2022, 11:43:58 AM
Vortex 22
Quote from: hartiberlin on May 28, 2022, 05:23:25 PM
I have deleted now the private Whatsapp number post.
Regards, Stefan. (Admin)
Thank you Sir
Vortex 22
I can upload a video now!
You can see, the charging process is slow!!!
We using 220 v 50 Hz only.
But it's for learning purpose only, later we can speed up much faster?
nix85
Funny. So we see a small cap charging at a rate around 1V per minute.
You would literally get more energy with a smartphone sized solar panel.
This cannot even be compared to powering a real load of 1100W from
the ground with 9W input.
Or even with Avramenko plug like this, powering a CFL light, probably
13 to 15 watts connected between one terminal of the coil and the CASE
of the cap, there is no closed circuit here.
https://www.youtube.com/watch?v=Iy1_J7ZjP7M
Vortex 22
This is not Don Smith tabletop device output 28.8 kw
This is the first baby step after that can walk and run !!!
If the effect is real we can maximize it
Do you remember, the first plane is not jumbo plane?
Your solar panels don't work in most times and in all places in the world?
Vortex 22
Quote from: nix85 on May 28, 2022, 06:59:41 PM
I admit it it's very slow process but it's good to show the ''anomaly''
Do you remember that Don Smith in most his devices
Using NST 9000 volts and 35.1 kHz? For the input
To add...
I want people to play with low voltage and low frequency first
Warning
Don't ever play with high voltage if you are not trained person in high voltage
