Capacitor Electrons Captor from Don Smith / Tesla
Started by Vortex 22, May 27, 2022, 11:43:58 AM
Vortex 22
―Grounding is a relative sort of thing. It's that ―there's more of something here and less of something here‖, so it's going to move between the more to the less, or something, 2001
Inventors Weekend - [https://www.youtube.com/watch?feature=player_detailpage&
v=W7GHqw7d1No#t=3106] Smith's capacitor ―trick‖ would appear to amount to agitating the ambient background, while ―presenting‖ to it a region of space (the ―B‖
plate of the capacitor) whose density of negative charges (electrons) is, or appears to be, lower than that of ambient. INSTANTLY, Nature moves to ―rebalance‖ the situation.
and it's that leg that's in between there that's your useful energy.
Smith's concept of ―proper ground‖ appears to have been the diametrical OPPOSITE of
―conventional‖ ―proper ground‖. His devices RELIED on ―silicone-related non-metals‖ as
generous DONORS of NEGATIVE CHARGES. Silicone is another word for SAND, which conventional ground connections quite specifically act to AVOID. But Smith was NOT seeking to ―dissipate away‖ ―excess‖ / ―stray‖ / ―transient‖ currents or other ―undesired
charges‖. That Pesky ―Little‖ Matter of ―PROPER GROUND
Vortex 22
Quote from: tomd on June 03, 2022, 05:37:06 PM
I think it's worthwhile. Just need to get everything clear in my head first.
This is the nst Don used: https://www.ventextech.com/products/vt4015-12/
But a suitable nst with a peak voltage of around 4000 volts should be ok. The ventex model doesn't require a inverter so that's less expense I guess.
The isolation transformer is another matter. However the output is 28.8Kw (480v at 60amps).
4000 volts output and 35 kHz?
Please don't earth this high voltage Input?  And you don't need a GFI
Galvanic isolation
tomd
@Vortex
Actually I think it's 25KHz. Just something I picked up from the Smith.pdf.
This one is 4KV peak, 30mA, 40Khz and no GFCI
https://a.aliexpress.com/_mKzuNIa
tomd
This is an electron captor. Could it be that the capacitor voltage rating isn't exceeded as charge doesn't accumulate to a sufficient degree. It is attracted to the positive voltage pulse and then goes back to ground.
kwag
