Veryy Big Contribution from Mr. Josep Newman for (FED Enthusiast)
Started by JackJohn, June 08, 2022, 01:37:37 AM
JackJohn
Just sharing my understanding about Free energy Device who's inspired by Mr. Joseph Newman's ideas
I'm not discussing About Mr Josep Newman Device but I'll try to explain How Mr Joseph Newman's ideas and techniques produce very large electromagnetic fields with very low power requirements way because this is very important and is the main requirement for achieving a free energy device.
Talking about generating electricity, it cannot be separated from 1. Strong magnetic or electromagnet (as an inducer) 2. Number of turns of enameled copper wire (conductor) 3. Speed ​​of changing induction poles (Frequency) 4. Number of Poles 5. supporting mechanical equipment
as I include in the picture of the physics formula below will explained that the strength of the electromagnet on the solenoid is determined by the Permeability of the Core X Number of turns coil wire X Current strength (Amp) / l (solenoid length)
While the voltage generated by the generator is based on the number of turns X Changes in the strength of the magnetic/electromagnetic field X cross-sectional area / time (seconds)
from the two formulas it is very clear that the strength of the magnetic/electromagnetic field is the main requirement for generating electricity.
How to produce a large magnetic/electromagnetic field with the lowest possible power required ??
  Thanks to : Mr.Josep Newman who has contributed greatly in opening our minds which so far considers that a strong magnetic/electromagnetic field can only be achieved with a large current only, he showed that a strong magnetic/electromagnetic field can also be achieved by playing with the number of turns of wire. (proven, from the low amperage and the large number of turns of the copper wire used, it is able to produce very large torque on His device). we can see that All Of His device playing A lot of number of turns of wire.
we also know that each size of copper wire diameter has a different resistance / Meter,it's mean more long = more high resistance.
the more the number of turns of copper wire = the greater the resistance of the wire = the smaller the amperage that can pass =
the smaller the power required but the magnetic field strength remains large.
is it true ??
Here I include image in the form of specifications for 2 stepper motors from 1 Big company which have the same dimensions, the same torque produced  but requires almost half the power consumption, please see the picture,
pay attention to the wire resistance, the strong current supply,the torque, the inductance in the specifications picture shown. I marked
hopefully it can inspire you to be able to increase creativity in the process of creating a free energy device.
Because the key above will actually applycable to Almost ALL the concept of FED both Motor Generator, Motionless Generator and also Joule Thief,Solenoid Engine Generator Etc
"Every Inventor has a little secret hidden about his device, and that secret is the success key of his device" Quote By Me  ;D ;D ;D
So stop Just looking at device models or designs, stop replicating Free energy devices from inventors because you will never succeed. But never stop studying their concepts, ideas while trying to find and learn the secret key to the success of the device and and try to combine it with the existing physics formula. Listen to the inventor's explanation, see the detailed video, then it is very likely that you can find the key in a few sentences or words from the inventor.
the (Last) bottom picture can be ignored, because it's just an idea in my head >>> 1 pulse dc supply = AC output in the secondary coil + Back Emf from the primary coil  ;D ;D ;D
"the law of conservation of energy states that the total energy of an isolated system remains constant"
if we look at this sentence, we can conclude that the electromagnetic induction that occurs during the EMF will have the same strength as the electromagnetic induction that occurs during the Back EMF but different direction, which means it will produce an AC current in the secondary coil.
JackJohn
norman6538
The Newman motor has been around for years and I have not heard of any OU Newman motor. The Bedini motor was likely OU in that it did two things.
1. A motor ran - mechanical and
2. the back emf charged a battery.
If that back emf was used to run another motor then 1 power unit in would run 2 motors giving 2 mechanical outputs.
As for the Newman motor and neos the coils have to match the neos or there will be "deadlocked flux". I never use neos until the concept is rock solid proven.
I wish you success.
Norman
norman6538
Your drawing looks a lot like the Bearden MEG with mags added. A German Kunel patent used coils and cores and mags. And Kunel said it works but not as drawn  which probably meant not linear but circular as your drawing and the MEG.
I spoke to John Bedini on the phone one time about the "Tilley Delorean" self charging elec motor car that ran on the NASCAR track in Tn. I was there personally and saw it but the wheel bearing went out and could not continue the run so we then went to Tilley's shop and examined it closely. Tilley had an armed guard at his fenced in property who was told to expect a group of 10 or so guys.
after several days John told me how he thought it worked but said lets keep the inventors secret. We did and both are dead now. If you like I can dig up the details and post them.
Norman
norman6538
I am currently in survival mode because the US and World is so screwed up it may not continue as we have know it for many stupid reasons.
Everything that is presented to you these days is faked and green-screened to make it look like you were elsewhere. We have not seen the congress in session for some time so whats up with that? Various doubles are using masks to impersonate the real person because the ear lobs change from double to double and in one case the mask was coming loose at the neck. I have not had the time to look for the photos that support that.
BUT things are very very very WEIRD in the US.
Norman
