Room for Free Energy and its Physics
Started by mrwayne, August 03, 2022, 10:33:43 AM
mrwayne
Quote from: mrwayne on August 03, 2022, 03:12:30 PM
New Thinking Required: LAW 1. Designed inequality of work or cost
Mr Wayne
Law 1. Designed inequality of work or cost
Part (a)
Reliability of expectation and Measurement
Since the work difference is a design feature, it is always measurable, predictable, and reliable.
A "remainder" is simply a value equal to the work differential minus system losses.
When the designed work differential exceed the systems losses, then a resultant "available source" will result.
Conversely, when the same system is run in reverse, and then the measured loss will be the same difference and plus the system losses..
While energy remaining has the appearance of creation, the reverse results in an non thermal, non potential storage energy destruction.
Mr Wayne
mrwayne
Quote from: mrwayne on August 03, 2022, 03:22:19 PM
Part (a)
Mr Wayne
Part (b)
Energy Creation/ destruction Scope application
When in the proper scope of designed differential energy can be generated and wasted outside the scope of a  thermal loss.
Thermal dynamics is the scope of conversion and consumption, and opposite and equal reactions, where the highest efficiency is attained by simplicity, reduction of loss, and friction.
Conversely Energy Causation can not be performed in a simple opposite and equal process - but it can be preformed with a series of simple systems; designed to be unequal.
Mr Wayne
mrwayne
What The Travis Effect revealed about the discussion of Over Unity
Unity is 1:1,
over/unity is OVER/ONE
anything >1/1 ....
Out put exceeding Unity.
Unity does not mean Input, that appears to be an assumption seemingly built up over time, and with good reason - without the discovery of an unequal work value, relationships, or unequal energy cost - unity might as well be changed to "InPut" as in output/input.
Yet as it turns out, reducing the cost of doing work,means being able to do unity work at a reduced cost.
(which the "Travis Effect" example is only one method I am sharing here).
This means that the Internal cost to generate unity is less than unity value of production.
Knowing the difference and knowing which claim is being made is critical to an evaluator.
Ignoring this fundamental fact levies the evaluator unqualified to judge the merits of a technology.
If the goal of building a system that provides continuous, clean, and abundant energy is i fact the goal - then you had better learn the difference between a system that lowers cost below ideal, and provides real free energy, and one that magically claims to exceed unity.
Thanks
Mr Wayne
p,s,
I am continually seeing some say - its not over unity - to which I say - if you really new what your were saying - you are correct- but the system I have shared produced energy to be externally consumed without input, without consumption of a resource, and without conversion of a power source. Boom
mrwayne
Now - Observation is an interesting thing - Side "B" is raised to demonstrate the Volume of Air as compared to side A
mrwayne
In this picture, the same volume as the previous picture is floating a distance above the concrete block
Side "A" is almost ready to start preforming work, while side "B"
Now Side A could perform the work over a longer distance - and longer distance is more power.
But Power is not defined by distance alone, "Tines Distance and Mass" must be considered.
