I Must Build The First RimJet (Clem Engine) ASP
Started by TommeyReed, August 24, 2022, 12:01:17 PM
TommeyReed
Hi All,
This is a test run on the liquid combustion chamber using compress air before using propane.
https://www.youtube.com/watch?v=9tNpVdOg_Wo
Tom
TommeyReed
Hi All,
I added a 2kw generator to this prototype liquid piston engine to test output when it use propane.
https://www.youtube.com/watch?v=A6Bshx1aHyY
Tom
TommeyReed
Hi All,
Been doing some calculation on injecting diesel into hydraulic fluid to increase pressure from 300psi to over 3000+ psi, not going to show the combustion chamber build. This becomes every dangerous due to the internal explosive power of diesel.
I plan to build a explosive chamber for safety, I would not expect other to do the experiment.
I plan to do a video after everything was tested, you know how others would try to copy something. I don't want anyone to get hurt or killed!
Tom.
