12 Kilowatt Free Energy motor generator for sale $4500
Started by e2matrix, September 11, 2022, 03:15:44 PM
indigo22
The principle is simple use a heavy weight flyweel. And as bedini said the energy to move that weight is differand. You do not have to lift it up and cary the load just have to tap the wheel to make it move,that way it's more efficient.
Ufopolitics
Hello to All,
Quotewhere does the energy comes from?
IMO, the center of the whole thing is about that huge flywheel...a gigantic kinetic energy storage...to the point he can afford to disconnect motor and still keeps generating power without much change in RPM's...nor Torque.
Realize the size of that flywheel...plus the fact it is mounted on a very thin shaft (related to its diameter and weight)...which must be perfectly well balanced...not an easy piece to build from scratch, first, you must have a very large Lathe to cut that size wheel.
Note the Outer mass of that flywheel, which have must of the weight concentrated on its outer circumference...this guarantee a steady torque and speed for a while, after it reaches its top-max speed (the 3 minutes initial run).
I believe it is real, however, too bulky, too spread out, plus he only uses a few hand power tools for a 12Kw generator...not a consistent High Load component, as is, an 80 gallons 15 HP Air Compressor as a simple example...and watching air pressure does not comes down, keeps steady...while just blowing air out. Conclusion: it needs much further testing which puts it at Surge (max load) or at least, very close to max load capacity...for a long while.
Related to the money, in my opinion...is too expensive...imagine the shipment cost, basically of that flywheel alone with all required mounting hardware, on top of the $4500.00...from one side of the World to the other.
While I do not think that any of the other two components (Motor and Generator) have much modifications done at all.
Just my opinion...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
ramset
Being an international open source forum with many members !
It has always been the case that we can get persons ( members) to help
View and test ( with assistance from other members here.
Typically persons who are just harvesting money always find issues to avoid
In person testing!
(I see indigo member posting here.... already primes that pump ( excuses)
We shall see ?
Respectfully
Chet K
PS
For clarity..in person testing or verification is a resource
Which will be presented to claimant!
Thanks Grandma
ariovaldo
Quote from: MagnaProp on September 12, 2022, 12:45:46 AM
There is a relatively inexpensive way to find out if this concept works or not. He is offering a 12 volt 15 amp version for 950 funds. He shows it being self powered in the video of the product page. If that is US 950$ then that's extremely inexpensive for a devise that works.
I'd put in 150 US$ toward seeing if that version gets delivered. If I thought it was real I'd buy the thing outright no problem but I haven't seen any satisfied customer reviews yet so I wouldn't be holding my breath on a return for that 150$
I'm in.
I can put $150 as well
ramset
good to see members here willing to help !
IMO
This is a win win regardless!
And a step forward for global open source FE community!
The wheels are already in motion towards a visit ( not verified yet ... , it's just the only way this makes sense when you have our global resources!
Hopefully will have info by tomorrow!
Respectfully
Chet K
Thanks Grandma
