Anonymous Schematic
Started by tomd, September 15, 2022, 06:22:26 PM
floodrod
So I wound 2 pancake coil layers like the diagram shows with some scrap coaxial cable. Threw on my signal generator and scope to take a peek at what's happening in it..
And yep, it's worth experimenting with..  Something I am finding interesting... Depending which way you hook the 2 center bifilers together, you can get the sinewave to do a
complete reversal and start to self-induct at Non-resonant frequencies...
It's pretty much the same thing I see when I bring coils to resonance..  When you hook a load or short the secondary, the input raises..
Any other transformer takes voltage away from the primary when you pull a load.. (except when it's at resonance)..
The good part is it can be done on standard motor operating frequencies, so it opens doors because it's not in the radio frequencies..
The bad part is the voltage is absurdly low..
I can't make any predictions yet, and I don't know what it all means yet- but I will be checking into this a bit further..
See the scope and hookup tests  here-  https://www.youtube.com/watch?v=Lj0UUSLB59E
floodrod
Today I got a Weird Effect while toying with a quad bucking pancake
IT SEEMS:
Weird bucking quad pancake as a prime mover in series with another coil causes things I have never seen.
Rotor speeds up as amperage drops drastically..  Back EMF is so strong that once it hits a certain RPM - the input current  goes so low that the rotor slows.
When RPM slows to a certain level, driver coil voltage spikes up 2+ TIMES the power supply voltage and speeds the rotor.  Input amperage amps come right back down as back EMF builds and the cycle repeats.
Wave form and phase totally changes between speedup and slowdown cycles.
Connecting a resistor load in various places kills the effect.  I will be playing with this more.
See the anomalies-  https://www.youtube.com/watch?v=9DoiQ1gcbMs
floodrod
Here are still shots of the wave / phase change between Slow-Down and Speed-Up Cycles.
It speeds the rotor until the input current is so low the rotor slows itself.  Then it raises current to speed itself back up while the coil voltage is over 2X the input voltage.  As is speeds up, the current drops until the current is so low it slows again.
Repeats..
(Note-  Yellow is just an open coil to have a reference.  Blue is the driver
sm0ky2
I know Mike Hunt, from personal childhood experiences
He's in the 99th percentile.
Despite the public reactions to (what science may consider) his autism,
The intellectual capabilities of this individual are superior to that of most humans.
sm0ky2
@floodrod
Take a DC motor
And attach a magnet to its shaft
so the pole-to-pole is perpendicular to the axis of rotation.
Using an asymmetrical field, indivisible by the proportional diameters of both fields:
(That of the magnet, and that of the internal motor magnets)
The rpm can never match, or be synchronized.
The second wave is always out of phase and shifting in time.
Causing a cycle of attraction and repulsion, speeding up and slowing down.
Like a pendulum which is heavier on one side of it's swing for a while, then flips around to the other side.
If you tried to adjust the phase, after a few cycles they would drift out of phase again.
The back emf is converting itself into forward momentum, then into braking momentum during the other phase of the process.
On some level these forces equal out, like an imbalanced flywheel
But the phase shifts can oscillate for a long time, as a derivation of capacitance
