audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
dxer_87
This is my last half baked idea, but I think that with a source this may be succesful. You need:
12V Power Supply
12/230VAC Inverter
2 classic transformers
unipolar cap
universal board with diodes and capacitors 1k resistor looped. 12V DC out.
Maybe not powerful, but keeper would fit here well. And this should be portable, no grounding needed.
dxer_87
Only thing to change may be the voltage of capacitors for 80-100 volts, because with AC current, even as low as 12-20VAC normal caps may be broken.
Con Duo should be energized at start. And plus/minus connected with 1k resistor.
dxer_87
Please can someone check if this works with modern amplifiers?
dxer_87
Possibilities move on :-). Only thing it sucks it's DIY xD. If everything will fullfill, my handbook will be up to date with fresh infos. Hope You all have a great day:-).
dxer_87
add con duo in parralells. more powerful source, more power overall :).
